Stage II questions?
Old Jun 18, 2004 | 07:09 AM
Eric Lyublinsky's Avatar
Stage II questions?
Hey guys.
Now what needs to be upgraded on the stock motor for Stage II. I know cams, and gears but are rod bolts and Head studs are must?? I want the whole thing equel lenth mainfold and 3037 with the smaller exhaust housing. (Street car runing on pump gas). Thanks fellas...
Eric
Old Jun 18, 2004 | 07:32 AM
Dyno4mance's Avatar
I would want rod bolts regardless of what is suggested....
Old Jun 18, 2004 | 07:43 AM
Who has had rod bolt failure? I don't think The One lap car had rod bolts.
Old Jun 18, 2004 | 07:50 AM
Dyno4mance's Avatar
Sorry Eric....just drawing from what they do in the UK...ralliart will install ARP's as a matter of course on any car heading for the north side of 320hp....and for an additional $60.00.
I would want them.....
Old Jun 18, 2004 | 07:56 AM
The only problem is really install. They are tricky to do it on the motor. It sounds easy enough but you know that is. Now what about head studs?
Old Jun 18, 2004 | 08:55 AM
Smogrunner's Avatar
I believe Joey C's motor had rod bolt failure, but I've never got the complete details.
Old Jun 18, 2004 | 09:00 AM
Ya I know,
Old Jun 18, 2004 | 09:05 AM
Dyno4mance's Avatar
I would think head studs are less important unless you are running silly boost levels.....
23psi up till red line is a conservative level of boost IMO...and would make a very potent but reliable daily driver...
Although this is speculation of course
Old Jun 18, 2004 | 09:09 AM
lambtron's Avatar
I thought he built his motor himself though? Anyways, we didn't change Shiv's head studs and rod bolts until we put the ported head on. The motor had well over 4000 dyno pulls(a little over 1k miles at WOT) and 20k+ miles on it before the rod bolts and head studs were touched. I'd still reccommend it though just to be on the safe side if you want to push 27-30psi.
Old Jun 18, 2004 | 09:55 AM
Dyno4mance's Avatar
Lambtron, has Vishnu got the sig cat delete pipes made yet?
ooops sorry about the thread hijack
Old Jun 18, 2004 | 10:02 AM
20k of Shiv abuse is good enough for me.
I migh to in and TQ everything but I'm not to keen on replacing rod bolts.
Edit what I really ment to say is
I might try to TQ the factory bolts in just to make sure they are with in spec.
Old Jun 18, 2004 | 10:13 AM
meanmud's Avatar
hope
I was thinking that mine was sent Tuesday
ooops sorry about the thread hijack - me too
Dyno4mance's Avatar
The point here though is what state of tune was Shivs car for the first 20k...
at what milage was the stage 2 installed?
sorry to be perdantic
Old Jun 18, 2004 | 07:11 PM
Dustin@Vishnu's Avatar
If your name is Troy, i sent yours out the other day.
