Message for Vishnu
Old Jun 27, 2004 | 12:11 AM
denom's Avatar
Message for Vishnu
Hey,
I have a dynoflash program on my car, and my question is whether or not you can reflash over it. Also I have a question regarding the new reflash that you do for $195. Does that control boost at all? I'd like to see a little over 19 psi. Also how can I calibrate my car to run on 100+ octane when I will typically only have 91 unless I am running at the track? Well please let me know when you have a chance. The dynoflash program actually reduced my trap speed by 3 mph, which has made me rather depressed. BTW my cars mods are: HKS hiper catback exhaust and a K&N panel filter.
Old Jun 27, 2004 | 03:48 AM
Dustin@Vishnu's Avatar
Hi,
We have a few different options for engine control. Our base option is the 195 dollar flash you mentioned. This flash does not control boost. Our next flash is the X map. The X map does raise boost, and obviously makes more power then our introductory map. X-Map is 395. Lastly, we have the Xede piggy back option, which sounds right up your alley. The Xede can hold a pump gas and race gas program, which can be toggled by a switch. The Xede is 895.
Sorry to be so brief, but i am heading out for our car and driver event today.
Old Jun 27, 2004 | 07:40 AM
jj_008's Avatar
X-Map = X-Flash. The X-Flash will raise boost and give you more HP. The XEDE is nice because it has user adjustable boost control, 2 maps (91, 100oct), custom maps on the web site, and soon to be released launch control, knock counter, datalogger, and wide band input.
Old Jun 27, 2004 | 07:55 AM
evo8power's Avatar
Kevin, don't push your luck. remember what you told me.
Old Jun 27, 2004 | 08:08 AM
Ludikraut's Avatar
Originally Posted by evo8power
Gee thanks for your informative post .... NOT!
Hey JJ_008 or SonicBramell ... any idea if the new XEDE features (datalogger, wideband input) will be ready by the end of July? (read: Chicago dyno day ) I have an LM-1 installed, and would love to be able to tie it into the XEDE. With the wideband input and datalogging, will I be able to then log AFR/RPM from the XEDE?
l8r)
Old Jun 27, 2004 | 08:28 AM
jj_008's Avatar
i woudl say learn how to drive is why you lost MPH.....just to let the vishnue crew know, BR500 turbo kit, HKS 272's, and a couple other goodies get installed fri night then a brand ne wDYNOFLASH!!!!!!!!!!!!!!!!!1 oh yeah Shiv!!!!!!!!!!!!!
You need to stop modifying your car and start modifying your brain. Community colleges take most applicants.
Old Jun 27, 2004 | 08:32 AM
jj_008's Avatar
l8r)
I wish I knew the release date. I remember Shiv posting a thread about the new datalogging feature and if I recall it would log AFR, RPM, knock, torque, MAF, timing, and probably something else I can't remember.
Old Jun 27, 2004 | 08:37 AM
Noize's Avatar
EvoM Administrator
Maybe middle-school and high school courses are in order first...
Old Jun 27, 2004 | 08:51 AM
evotomig's Avatar
Good one.
In order to get into a college,though, you need to be a high school graduate, or at least have a GED.
Old Jun 27, 2004 | 09:05 AM
Smogrunner's Avatar
Hey Evo8,
You should ask Robi why he had to leave Al behind in favor of a stand alone ems. Why would you get a flash for that setup? A flash will be fine for pump gas but your future setup will WANT to be unleashed on race fuel. Then what?
Old Jun 27, 2004 | 09:08 AM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
You know, this would be a much better place if Al's followers stayed out of Shiv's threads and Shiv's followers stayed out of Al's threads.
Old Jun 27, 2004 | 10:00 AM
Quickshift's Avatar
But that never happens!!!
Old Jun 27, 2004 | 01:32 PM
denom's Avatar
Where shall I start with this one. First i'm not the best driver, but any monkey can speed shift at redline. I was trapping at 99 mph before the dynoflash, and am now trapping at 95 mph!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! That is pathetic. There was a lightly modded WRX Wagon running faster trap speeds then me there. Here was my best time slip at Speedway:
R/T .638
60' 2.022
330' 5.807
1/8 8.992 @ 77.98 mph
1000' 11.736
1/4 14.057 @ 95.82 mph
Old Jun 27, 2004 | 01:43 PM
evo542's Avatar
your 0-60ft is a bit low, with some practice you can shave .2sec off your launch
Old Jun 27, 2004 | 02:59 PM
denom's Avatar
Actually I think track conditions played a part in the 60'. I've heard that Irwindale is leagues better traction wise compared to Speedway.
