quick question
Old Jul 14, 2004 | 11:35 AM
  #31
Az3ar's Avatar
did you read the last sport compact? Shiv dyon was about 50 whp less than all dyno jets with that truck. some dyno jets are different I am sure.
Old Jul 15, 2004 | 12:23 AM
  #32
IE Evo's Avatar
Maybe newer Evos for 04 have worked out some of the knock issues on 91 oct and have been Flashed a lil more aggresively. I believe Shiv's and Lamptron's newer Evos dynoed 10-20 hp higher than the earlier or 03 Evos. Also I believe the pinging that the Sti was experiencing after its release called for a reflash that probably was less aggresive than the mags preproduction Stis.
Old Jul 15, 2004 | 12:31 AM
  #33
shiv@vishnu's Avatar
Originally Posted by alex_alex
This seems consistent enough, until you look at the stock EVO's, which were dynoing 240 hp (which was, incidentally, about 5 hp more than STI's were dynoing at stock).
I've never seen a stock EVO dyno more than a stock STi. Stock STis have always put more to the wheels than stock EVOs. The difference has always been 15-25whp which is what one would expect given their factory bhp ratings (271 vs. 300). If you see otherwise, something is amiss with either testing procedures or car set-up. For instance, did the STis get a fan placed on their TMICs as well as in front of their radiators?
Shiv
Old Jul 15, 2004 | 07:06 AM
  #34
alex_alex's Avatar
Shiv
No, there was just one single fan. Could that explain it?
If that were the case, however, would that mean that every single regular WRX tested low as well?
