Boosting over 22psi??
Old Jul 19, 2004 | 04:20 PM
BOOSTEZ's Avatar
Shiv-team,
I've been loving the XFlash and looking forward to some more modding.
I've got a few questions however. What does the Sub-Zero do to the rpm, boost fuel cut? I noticed that my fuel cut out at 8krpms last night when racing it. I also bought the new HKS SuperFlow drop-in filter and my car seemed slower. I would've thought that my car would pick up a little more HP (with the airbox still in place) since the filter consists of the same design as the PowerFlow filters. I noticed that my boost would go to about 20.5psi and taper off a little. When I put my stock filter back in, I got 22.5psi!! What's going on that the XFlash is tuned to just the stock air filter? I've wasted a few bucks already trying to free up the intake and get a little more power - all to no avail.
-M
Old Jul 19, 2004 | 05:01 PM
Jaylenospoolboy's Avatar
Do a thread search. This topic has been covered. Stock air box works best from what I've read as it's made to work w/ MAF sensor and some of the aftermarket filters don't work as well.
Old Jul 19, 2004 | 05:14 PM
SuperHatch's Avatar
He has the stock air box still, he's just using an HKS drop in filter. If the filter alone is causing the problem, this is a new one to me.
- Steve
Old Jul 19, 2004 | 06:12 PM
Dustin@Vishnu's Avatar
Something is a bit strange here. I am willing to bet that the testing method is a bit flawed. When talking it over with Dave and Shiv, we determined that there is no possible way the different filters could create a delta that large, unless the HKS is MASSIVELY restrictive (Which is highly unlikely). In any event, I would sugjest putting in the stock filter, as that is what your flash was tuned for.
Old Jul 20, 2004 | 04:30 AM
Ludikraut's Avatar
The HKS drop in filter (green) will NOT net you any significant HP ... all it will do is lean out the AFR slightly. I have one installed on my Evo along with a Vishnu stage 1 ... results of the HKS filter on my Evo are:
- BOV is louder
- AFR is ~.5 leaner, which equates to <5whp and can be attributed pretty much to the leaner AFR
Did you modify your intake in any other way?
l8r)
Old Jul 20, 2004 | 06:11 AM
Noize's Avatar
EvoM Administrator
8000rpm?
You should've cut by then anyway, due to the rev limiter.
Old Jul 20, 2004 | 05:52 PM
BOOSTEZ's Avatar
- BOV is louder
l8r)
Nope. I put the stock filter back in. I'm not going to deal with anymore aftermarket filters, including K&N.
Thanks,
-M
