Bushur Upper IC Pipe Kit and Vishnu Stage 1/1+?
Old Sep 21, 2004 | 01:05 PM
  #31
ez76's Avatar
Originally Posted by Porsche518
For effieciency and power the BR IC piping is unparralel.
How did you determine this?
Old Sep 21, 2004 | 03:47 PM
  #32
4G63>OOOO's Avatar
Ah, quit arguing, look at my dyno chart and you'll draw the logical conclusion that since I have the upper pipe and I made 380whp, if you get the upper pipe, you will also make 380whp.
Old Sep 21, 2004 | 09:08 PM
  #33
sanantone's Avatar
BR UIC does work with stock air box. Definitely a tight fit, but does work. I have that combo XEDE, BR UIC, stock box, as well as other mods.
Old Sep 21, 2004 | 10:57 PM
  #34
Ludikraut's Avatar
Sweet! Looks like that's the route I'll be taking... ... not only will I then also make 380whp like 4G63>OOOO, but I figure if I add a Vishnu decal I'll be good for 400whp easy
l8r)
Old Sep 21, 2004 | 10:59 PM
  #35
alex_alex's Avatar
Old Sep 21, 2004 | 11:00 PM
  #36
alex_alex's Avatar
im getting my custom made upper IC pipe put in on Friday by Road Race. Nice, cheap (< $100), and works perfectly with the stock airbox, no compromises. ill post pics when i get the pipe put in.
Old Sep 21, 2004 | 11:30 PM
  #37
mitsuorder's Avatar
gotta love some custom goodness
Old Sep 22, 2004 | 01:27 PM
  #38
Ludikraut's Avatar
Hmm, in a flash of inspiration, I think I might pursue the following possibility... since I am going to be relocating the stock battery and IC sprayer reservoir, I'm thinking I should be able to have an upper IC pipe fabbed that basically curves around or under the stock airbox into the TB. Basically that should then eliminate just about all sharp bends. One question, though ... what's the consensus on using stainless steel vs. aluminum?
l8r)
