Bushur Upper IC Pipe Kit and Vishnu Stage 1/1+?
Hi all,
I'm getting tired of blowing my air intake hose off the throttle body, so I'm investigating some improved solutions (crazy glue is starting to look good). Obviously Vishnu sells Samco hoses. I'm not really thrilled about using hose, so I'm curious to see if anyone has used the Bushur Upper Intercooler Pipe Kit on a Vishnu stage 1 or 1+ car?
Thanx...
l8r)
Thanx...
l8r)
Originally Posted by alex_alex
id imagine very few do, primarily b/c the Buschur pipe requires you to run an open element intake, which most Vishnu-ers dont have, unless theyve been custom tuned by Shiv.
Thanks for the info.
l8r)
Gruppe-S will soon be getting Helix IC pipes that should work w/ the stock air box. I have talked to Cal a few times about this and may even let them test fit on my car since I still have my stock air box and have no intention of replacing it.
I've read in one of the threads that the Buschur upper intercooler pipe does work with the stock air box. If you are interested in good T-Bolt clamps, these guys make some great ones. http://www.hosetechniques.com/
couldn't you run something like the rallyarmor battery tray offered here in EvoJimbo's group buy? https://www.evolutionm.net/forums/sh...t=battery+tray
I really like this tray, obviously works well with the Braile battery I run, looks snazzy and also looks like it would clear the stock air box.
Another possibility is the Dejon Tool upper intercooler pipe http://dejontool.com/Evolution.htm#U...rcooler%20Pipe. I E-Mailed them a while back and they said that their pipe will clear the stock air box and will work with the stock battery as long as you used a stock style BOV.
