Max power on stock turbo with 91 oct
Old Aug 3, 2004 | 10:51 AM
559EVO's Avatar
What dyno numbers have you seen and what else was used or can be used to maximize a stage 1+ car?
O2 Housing?
Manifold?
Intercooler/piping?
Old Aug 3, 2004 | 12:45 PM
954DRGSR's Avatar
tubular manifold.
head porting.
Old Aug 3, 2004 | 12:50 PM
meanmud's Avatar
RNR's tubular manifold looks and sounds impressive - They said they would develop one for the stock turbo if there was enough interest. Also, Borla has one with a Lifetime Warranty.
Vishnu any opinions on their (RNR/Borla) manifolds?
Old Aug 4, 2004 | 07:21 AM
meanmud's Avatar
bump &
sounds like a tubular header would make a complete stage 1+ IMO
Old Aug 4, 2004 | 09:56 AM
954DRGSR's Avatar
nitrous.
Old Aug 4, 2004 | 10:35 AM
alex_alex's Avatar
no no no, not on a car with advanced timing. from what i understand, that is really bad news.
Old Aug 4, 2004 | 10:59 AM
Wizard_of_Evo's Avatar
i am sure shiv could tune the xede for the nitrous. at least i hope he can, because i am leaning in that direction after my stage 2 is complete.
marc
Old Aug 4, 2004 | 03:27 PM
559EVO's Avatar
No info from the Vishnu guys yet,I know they have read this???
Old Aug 4, 2004 | 04:20 PM
gnulooks's Avatar
Most guys w/ the stage 1+ are pretty much at the limits of their stock turbos. I am not too sure if Shiv recommends putting an aftermarket exhaust manifold because the stock one is a perfect match for the stock turbo. Plus their expensive and there might not be that much of a gain in horsepower. I believe Vishnu is working on some type of turbo housing that is off the Evo VI, which might give an easy 10-15 more ponies.
Old Aug 4, 2004 | 04:44 PM
David@Vishnu's Avatar
Originally Posted by gnulooks
Most guys w/ the stage 1+ are pretty much at the limits of their stock turbos. I am not too sure if Shiv recommends putting an aftermarket exhaust manifold because the stock one is a perfect match for the stock turbo. Plus their expensive and there might not be that much of a gain in horsepower. I believe the Vishnu is working on some type of turbo housing that is off the Evo VI, which might give an easy 10-15 more ponies.
True and the reliability issues. We will see if there is advantages of the 10.5 as well as tubular mannies but in all honesty a stage 1 on racegas or octane increaser is an absolute blast on the road and track
Old Aug 4, 2004 | 10:30 PM
evotomig's Avatar
Picked up 8 whp w/ upgraded intercooler on 91 pump....BUT 27whp on c16 racegas.
FYI
Old Aug 4, 2004 | 10:38 PM
Smogrunner's Avatar
FYI
You have my attention! Tell us more.
Old Aug 4, 2004 | 11:08 PM
gnulooks's Avatar
Looks like NorCal Tom has found us more power...
Old Aug 4, 2004 | 11:17 PM
Smogrunner's Avatar
I'm getting a chubby....
Old Aug 5, 2004 | 06:19 AM
evotomig's Avatar
Slapped on an upgraded intercooler (which shall remain nameless) and had Shiv retune the car on both 91 and C16.
He pulled out 280whp on the 91 map w/ no problems.
Next came the racemap. First pull 342whp. Holy shi*. I couldn't believe it. I was thinking I might pull low 320s at most. Next several pulls were in the 340+whp range.
All of a sudden Shiv was getting something similar to a cut in the upper rpm ranges on the next few runs. To be on the safe side he detuned the map a bit.
Seems we found the limit of the stock injectors. They do not seem to like anything over 320swhp on Shiv's dyno. (360whp dynojet whp)
The lesson learned from the tune:
the stock turbo is not as small as thought. On racegas w/ stage 1+ and upgraded intercooler and injectors 350whp on dd dyno or (400whp dynojet)
is possible.
On the streetmap an upgraded intercooler will not yield as much gain. I gained 8whp on 91. On a 93 map perhaps 12-15whp is a definite possibility.
Hope this helps. Sorry for hijacking the thread a bit.
