Vishnutuning.com down!!!!!!!
Old Sep 5, 2004 | 08:33 PM
the-moss's Avatar
Cool, thanks Shiv, I appreciate your time helping a newbie here...
Old Sep 5, 2004 | 08:35 PM
n00dle's Avatar
Originally Posted by shiv@vishnu
The XEDE doesn't control water sprayer without additional wiring to the harness.
shiv
you figured out the wiring off the ECU to implement it on to the Xede harness?
I feel like i'm the only one eagerly awaiting for this feature.
When can I send my harness is for an upgrade?
Old Sep 5, 2004 | 08:39 PM
the-moss's Avatar
I'm with you n00dle.. This feature would be very cool... Plus it would be something I could fiddle with without fear of blowing something up.... Well I guess I could burn a water pump out, but that doesn't count.....
n00dle, in your wiring, will the stock switch still override the sprayer? i.e. if the switch is off, we never spray, if the switch is on auto then Xede has control, and if switch is on 'spray right now', then we are spraying right now?
Thanks
Alex
Old Sep 5, 2004 | 08:44 PM
n00dle's Avatar
Thanks
Alex
Currently the Xede doesn't have any control of the sprayers at all. There's no wiring going from the ECU to the XEDE and vice a versa. This is a feature i've been hoping to see Shiv make possible. The switch currently operates like intended from the factory with no Xede input.
Old Sep 5, 2004 | 08:48 PM
the-moss's Avatar
Sorry, I totally misread your other post.... Dyslexia at it's best..
I read :
"you figured out the wiring off the ECU to implement it on to the Xede harness?"
as
"I figured out the wiring off the ECU to implement it on to the Xede harness!" What a dumbass!!!!!
Old Sep 5, 2004 | 08:51 PM
n00dle's Avatar
