Vishnutuning.com down!!!!!!!
Need help - Vishnutuning.com down.
Help I need to download the map loading software....
Hopefully this is just a call to your web guy...
In the mean time, if someone is feeling REALLY generous, could they e-mail the install instructions and the Stage sub-zero 93 oct map to me?
Yay someone just e-mail the map I need to me... Thank you so much... Now all I need are the instructions to install the Xede....
My e-mail address is the-moss@usa.net
Could someone please e-mail the sub-zero 93 oct map and the install instructions to me please??? Thanks... Alex
E-mail address is the-moss@usa.net
Last edited by the-moss; Sep 5, 2004 at 08:28 AM. Reason: Email address would be helpful
back in the ol days the server was in Fl. i dont know if it still is but NASIOC.com is also down. nick emailed me stating that he might have to pull things down if the storm got too bad. *fingers Crossed*
Tom
Tom
Tom
Tom
shiv
Hey Shiv, or anyone actually.
Seeing as you are sitting around twiddling your thumbs with nothing to do right now (riight). Do you know what the modification date of the latest stage sub-0 map is? The one I have which was kindly e-mailed to me is 8/13/2003.
Thanks,
Alex
Thanks,
Alex
I don't know to tell the truth. I'll have to wait until the website is up to look at the last update date
Go ahead and use the one you have as it should be fine. Sub0 maps haven't changed much over time...
thanks to those who offered help!
Shiv
Go ahead and use the one you have as it should be fine. Sub0 maps haven't changed much over time...thanks to those who offered help!
Shiv
I agree thanks for the help guys, it is hugely appreciated...
The car feels a bit stronger than it did, however it is humid as hell today...
I have a quick question.... I was just running around with my laptop plugged into it, I was running the XUpdate software.
I was seein TPS values of 2.2-2.4 volts and MAF values of 0-0.4ish (I wasn't looking at it at WOT for obvious reasons).... However the MAF value seemed to go up and down with the amount that I pushed the throttle, but the TPS seemed to just wander up and down as it saw fit... Are these two values switched on the display? Are the values I'm seeing normal? The car seems to drive fine, the green light is on the Xede and I have no CEL.
Thanks
Alex
Thanks
Alex
So what is it reading then to give it the 2 volts? If it's a Vishnu secret I can handle that.
Also another quick question is, the software has this water spray thing on it... Does the Xede actually control the sprayers if I 'burn' that map?
The XEDE doesn't control water sprayer without additional wiring to the harness.
shiv
