Map Picking Q...
Old Sep 9, 2004 | 10:33 AM
MayhemSi's Avatar
Map Picking Q...
Ok... well hks 264/272 cams are here and I'm about to embark on the install, w00t! Anyways, I have downpipe, testpipe, exhaust, xede, and now the cams, but no cam gears at this point. Will I be safe running the cammed maps off the vishnu site until I can get the gears and set them to -2 -2? I have a PLX wideband in the car right now so I should know if its running ridiculously lean, my only complaint is that the sensor is really slow compared to an FJO, etc. Anyways.. its my daily and I need a map to be fun but safe.. Thanks!
Old Sep 9, 2004 | 02:30 PM
MayhemSi's Avatar
Yay! noone knows! hehe
Old Sep 9, 2004 | 06:15 PM
David@Vishnu's Avatar
Youll be OK of course not totally as snappy as could be
Old Sep 10, 2004 | 01:00 AM
MayhemSi's Avatar
Ok.. well I was concerned about the map being too aggressive.. I've been running 91 octane maps most of the time here in Texas with all the heat. Once it cools off... for two days... in december.. I'll run the 93.. heh. Jk. Its not that bad, but it defintely gets too hot. As long as the map is on the good end of things I'll be fine. I got the wideband installed tonight so I should be good to go
