Quick help! Question about Stage 1+ map
Old Sep 11, 2004 | 10:08 AM
eazyevo's Avatar
Is it ok to run the Stage 1+ map w/ XEDEFLASH ... without the xedeflash ? Thanks!
Old Sep 11, 2004 | 11:29 AM
shiv@vishnu's Avatar
Yes... you can do it. However, in the winter, you may need to turn down the boost by a 1psi or so or you might run into the factory boost cut (which is raised by the XEDEFlash).
Shiv
Old Sep 11, 2004 | 11:41 AM
eazyevo's Avatar
Cool. Thanks! All i needed to know. I will be at the dyno day in the beginning of Oct. so I'll only be w/o the xedeflash for about a month. Installing the cams today. Thanks!
-Ceez
