Do I need a fuel pump?
Old Sep 17, 2004 | 10:19 PM
denom's Avatar
Hi,
I have the following mods:
Helix Downpipe, stock catalytic converter, HKS catback, K&N filter, Xede piggyback, and Vishnu cam gears. My question is if my car is safe for just short 1/4 mile sprints. I plan on getting the Walbro, but I want to run it at the track tomorrow. Please let me know when you have a chance. I'll be running 104 octane.
Old Sep 17, 2004 | 10:24 PM
chronohunter's Avatar
I think you're ok for 1/4 mile but you should get a Pump ASAP. I took 20+ sucessive dyno pulls to get it to lean out on the stock pump. So one 1/4 mile run every 20 minutes or so should be fine. Someone with more drag racing experience may want to weigh in. BTW the pump is a quick 30 minute install
Old Sep 17, 2004 | 10:33 PM
denom's Avatar
Thanks for the information. I won't be running that much actually. Speedway is quite crowded. I figure i'll get a run in every hour or so.
Old Sep 17, 2004 | 11:11 PM
lambtron's Avatar
You should be fine, but it's not a bad idea to get the pump at your level of modifications. It's just one less thing to worry about if you upgrade your cams
Old Sep 17, 2004 | 11:40 PM
denom's Avatar
Thanks for the information once again. I don't want to buy cams. I really want to avoid that. The only other performance mods I want are the pump and a high performance catalytic converter. I want to concentrate on cosmetic mods shortly.
