Stalling Issues
Old Sep 19, 2004 | 08:43 PM
statix's Avatar
Stalling Issues
Hey guys, since being tuned by Shiv with the exede my car stalls all the time and idles very low. I have the 272 intake and exhaust so I know there issues there with the idle, but the car pretty much never stalled until after the tune. Also I was thinking of putting a 264 intake in because the car is gutless of the line especially when its hot out, would I need to be re-tuned or should it be ok just dropping it in.. Thanks..
Old Sep 19, 2004 | 09:15 PM
n00dle's Avatar
What blow off valve are you running. That could be causing the symptoms...
Old Sep 19, 2004 | 09:22 PM
Ludikraut's Avatar
Do you have adjustable cam gears? ..and if so, what are they set to?
l8r)
Old Sep 19, 2004 | 09:24 PM
shiv@vishnu's Avatar
Try turning up your idle bypass screw a bit. This will lessen the amount of work your idle control motor has to do when it comes to stabilizing your idle speed. Bring it up to 900rpm and you should be fine and dandy.
Shiv
