Ralliart carbon shift panel.
Jacky,
Which Part Of The Console Has To Be Trimmed? Is It The Ralliart Shift Console Itself Or Is It The Stock Plastic Oem Bottom Piece That The Ralliart Piece Sits On Top Of? Do You Think The Jdm Oem Bottom Piece Would Fit In The Usdm Car Because I Know That The Ralliart Part Would Attach To That Without A Problem But Am Not Sure Whether The Jdm Stock Piece Would Fit Left Hand Drive Car. Would Think It Would Fit And If You Got Both Pieces Would Not Have To Modify Anything.
Ex-sti Guy
Ex-sti Guy
Doesn't fit the way it's supposed to. It's a RHD piece and the console is not perfectly symetrical...it angles sharper to the passenger side. That little bit of difference caused me hours of dremmel work and customization yet the damn thing still doesn't sit flush. I'm going to go back in and hold it down with zip ties.
Originally Posted by value
Mine looks like that from the front too. How's it look from the sides? Does it sit flush or is there a gap where it meets the console wall?
Originally Posted by BADEVO
Depending on what all is involved I may order this too. Holding off till I see how much modification is required.
You'll need a dremmel to clean out the places where it rubs on something inside of the console. It's all plastic. Then you'll need some wires spips to cut off all the teeth on the base off the new cover. The gap pattern on the stock console doesn't match the teeth pattern on the Ralliart Piece. After you've done that get a grinder or some 60 grit sand paper. When you try to put the cover on for the first time note which edges on the Ralliart console are preventing it from sitting flush. Sand accordingly. Put back in place. Measure. Remove. Repeat.
