Ralliart carbon shift panel.
Do you guys know where I caould get that Ralliart carbon shift panel and how much it is? My stock painted piece is pretty scratched up from a short throw shifter install and I'm looking to replace it. Thanks.
we can get it, it takes 4-6 wees from japan and needs to be shaved down a little to fit our spec evo. we forgot how much it cost. so im waiting for my rep in japan to email me back.
jacky
jacky
Just a few more questions. I see the lighter and ash tray are reversed due to the right side drive overseas. Will this still fit on the US Evo 8? Also, you said it had to be shaved a little bit to fit. What does that recquire? Is it something anyone can do themselves? Thanks!
I guess I'm not quite sure what "shaved" is then. Is this something you do with some high grit sandpaper or is cutting recquired? I just don't want to mangle this piece.
ok, the difference is the bottom of the console. the arches there are than our version. you will need to trim it down little by little then sand it down till it fits. you will not be able to see the ugly trims that you made once its installed.
What about the lighter and Ashtray? They are reversed, i havent taken the console apart yet, but can they just be switched around no big deal? i Know on other cars the light assembly is pretty easy to take out if need be. IS this the case here? Cause that thing = The Hotness!
