Vivid Racing - Arizona With the best JDM selection of parts for your EVO and a great experience for your EVO upgrading, Vivid Racing is here to answer your questions and needs. [Visit Site]
What VIVID does on the weekends
Old Oct 27, 2008 | 11:38 AM
Vivid Racing's Avatar
What I did this weekend since I wasnt at Vivid working:
I rebuilt my "drop in piston" motor. I didnt do the rings right last time so they didnt seal right (too tight) as you can see in the first few pics.
Head... no bent valves!!!
Some carbon build up
Seems as if the top ring didnt seal well
Do a slight hone,
Cleaning, take the pistons to the polishing wheel to make them silky and smooth
Checking end gap and filing
New valve seals
Assembly...
It took a total of 19 hours. Taking time making sure it was done right. Will see after break in how it does. It was a long/but fun weekend. VIVID RACING can supply you all the parts necessary for a build like this. We can also provide first hand experience for install questions
This is a great "cheaper" alternitive to a full tilt motor build. A build like this should hold 600 whp with no problem.
Thanks for looking!
Evan Smith
Old Oct 27, 2008 | 11:57 AM
badhabit90's Avatar
Cool
nice job Evan!! great pics and insight to what goes on inside a "drop in piston" engine. perhaps you could show what pistons, rods, rings you used and maybe some MSRP on the parts total including gaskets and such...??
Old Oct 27, 2008 | 12:14 PM
Ill work on getting prices together...
Arias pistons 85mm and rings
Eagle Rods
Oem Head gasket
Cosworth rod bearings
Arp head studs
Oem valve seals (optional)
You can pick your engine internals here; http://www.vividracing.com/catalog/e...4206_4504.html
http://www.vividracing.com/catalog/e...4206_4506.html
^^^ Dont see a brand name you want? Call me we can get it!
Evan Smith
Old Oct 27, 2008 | 07:14 PM
Jim in Tucson's Avatar
Evan, did the drop-in pistons change your compression ratio?
Old Oct 27, 2008 | 08:29 PM
vtec2mivec's Avatar
Nice!! What pistons did you have in there before Evan?
Old Oct 28, 2008 | 08:22 AM
Yes sir a little lower 8.5:1 (Better for high boost)
Old Oct 28, 2008 | 08:29 AM
I used the pistons that came out of the motor. Arias... I took them out to see little to no scuffing on the side wall, so I had a good idea that my piston to wall clearance was ok. I cleaned the carbon off the top, then polished the pistons. After they sat in soapy water for 30 min I scrubed and rinsed them. Good as new
Evan Smith
Old Oct 28, 2008 | 08:52 AM
vroomevo's Avatar
awesome...
maybe this is what i need to do...
Old Oct 28, 2008 | 09:12 AM
LMK Vroomevo... You, Rick, Edwin, and I could all do it.
Old Oct 28, 2008 | 09:29 AM
CroatianKid's Avatar
I want a 2.3rr from ams with a gt850r.
Old Oct 28, 2008 | 10:26 AM
aka03's Avatar
nice work evan.. looks clean man..
Old Oct 28, 2008 | 12:00 PM
Thanks!
Evan Smith
esevo
16
Nov 7, 2011 07:34 PM
esevo
15
Apr 13, 2010 11:52 PM
esevo
33
Mar 26, 2010 11:47 PM
esevo
32
Apr 12, 2008 08:16 PM
