Vivid Racing - Arizona With the best JDM selection of parts for your EVO and a great experience for your EVO upgrading, Vivid Racing is here to answer your questions and needs. [Visit Site]
Exedy Clutches Blow Out!!!
Old Jan 8, 2009 | 01:24 PM
vividracing2's Avatar
We just got a ton of Exedy Clutches in stock and want to get rid of them!!
Exedy Wasabi Twin Clutch Kit Mitsubishi EVO VIII IX MR 03-06
Model: MM022HD List: $1,645.11 PM for the best price!!!
This kit features a large increase in the required pedal effort from stock. The pedal is considerably stiffer than the Sport Pressure Plate, but the trade off is increased holding capacity. Exedy's Wasabi twin-disc cerametallic design is rated to 505lb-ft at the flywheel for drag racing and 625lb-ft at the flywheel for road racing. This kit includes a chromoly flywheel. If you're not making this much power and don't want the increase in pedal pressure, we suggest the Sport kit, sold above.
TORQUE CAPACITY: 505 lb-ft. flywheel for drag racing, 625 lb-ft flywheel for road racing.
Specs
Number of Discs TWIN
Spring Damper Discs YES
Clamp Load (Lbs) 2920
Disc Outer Diameter 200
Spline Teeth / Major Diameter 23T / 26.2
Fits: Mitsubishi EVO VIII / MR / IX "Pull Type Clutch,5Spd & 6Spd, Heavy Duty" 03-06
Exedy Hyper Twin Plate Clutch Mitsubishi EVO VIII MR IX 03-06
Model: MM022SD List: $1,584.18--- PM For best Price!!!!!
Dual sprung hub 6 puck cerametallic disks which will easily support 500+ crank lb/feet of torque. The twin plate clutch developed for motor sport is designed for higher torque, while at the same time featuring a reasonably light touch on the pedal control. The twin plate clutch boasts the substantial torque capacity and sensitive response called for in high-performance sports cars. In addition, for drivers looking for an even higher torque, specialized hard settings are available. Two separate settings allow the driver to select the type that matches his or her individual preference. The twin plate clutch used in Daikin clutches manufactured by EXEDY Corporation are available in both push and pull type models. Does not include throw out bearing. Includes flywheel.
Clamp Load (lb): 2205
Spring Damper Discs: YES
Spline Teeth/Major Dia(mm): 20T / 22.4
Disc O.D. (mm): 200
Notes: Pull Type Clutch, (CN, CP, CT9A), (2,6)
Fits:2003-On Mitsubishi Lancer Evo VIII / MR / IX 2.0L 4G63T Turbo, pull type clutch, (CN,CP,CT9A)
Exedy Hyper Twin Clutch Hard Disc Mitsubishi EVO X 08+
Model: MM062HD Sale: $1,861.44 PM For Best Price!!!!
For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application.
Number of Discs: Twin
Spring Damper Discs: SPRUNG CENTER DISC
Push / Pull: PULL TYPE
Disc Outer Diameter: 200mm
Spline Teeth / Major Diameter: 23T / 26.4mm
Exedy Hyper Twin Clutch Soft Disc Mitsubishi EVO X 08+
Model: MM062SD Sale: $1,861.44 PM for Best Price!!
PM ME FOR THE BEST PRICING!!!
If you have any questions please dont hesitate to ask!!!
Old Jan 8, 2009 | 01:37 PM
Evo Girlie's Avatar
pm me price shipped to 33351 for MM022HD
Old Jan 14, 2009 | 03:08 PM
Bump!!!!!!!
Old Jan 14, 2009 | 05:30 PM
Slim@Turbotrix's Avatar
the exedy hd is still alil pricey
Old Jan 14, 2009 | 05:53 PM
That is just the sale price on the site. People can PM for a much lower price
VR
Old Jan 14, 2009 | 06:09 PM
boostGotMeLaid's Avatar
are these hard to rebuild or do u sell rebuild kits??
Old Mar 6, 2009 | 10:26 AM
NRG's Avatar
NRG
How is the pressure feel compared to stock on the MM062SD?
Old Mar 16, 2009 | 06:07 PM
xturdfergusonx's Avatar
price on MM022SD shipped to 98321??
Old Mar 16, 2009 | 06:33 PM
Vivid Racing's Avatar
PM sent.
