Progressive injection Vs. on/off injection
Old Sep 4, 2007 | 08:40 AM
Ultimate CC's Avatar
we just need malibuJack for a week ahha...
Old Sep 4, 2007 | 04:41 PM
Richard L's Avatar
Originally Posted by C6C6CH3vo
Are the high speed valves contollable outside the IDC range through RPM? If so then why not look in to a patch for ECUFlash that can run the HSV that will run any value you like at any rpm vs load
I am not sure if you are asking if the HSV can be controlled by the ECU's spare PWM output? or spliced into an existing fuel injector?
Old Sep 4, 2007 | 06:37 PM
C6C6CH3vo's Avatar
A HSV contolled by a map similar to, but seperate from, the AFR map. Somehow contoll the HSV duty by RPM vs LOAD, without closed loop of course
Old Sep 4, 2007 | 06:42 PM
Richard L's Avatar
If you have a spare PWM channel on your ECU, you can easily do that with the HSV.
I believe Element 's Hydramist is already doing that, not sure if it is available for the EVO.
Old Sep 5, 2007 | 05:07 AM
deadbeatrec's Avatar
so then the HFS-1 is......
and the HFS-5 is.......
im still cloudy on the differences between the two. is that the difference, one is on/off and the 5 is progressive?
Old Sep 5, 2007 | 05:23 AM
SlowCar's Avatar
hfs-1 = on/off (system fires full blast once the trigger point is reached)
hfs-5 = high speed valve (HSV) pulses in sync with 1 of the fuel injector once trigger point is reached
both are constant pressure injection systems - you get maximum atomization, which is crucial for good distribution of injectant down the 4 intake runners
hktrigguy
Oct 31, 2016 07:50 AM
boomn29
28
Feb 14, 2007 10:29 AM
djevoawhp
10
Jul 16, 2006 08:43 PM
Billy17425
Apr 23, 2006 06:04 PM
teamdomokun
Sep 13, 2005 12:45 AM
