SMC Failsafe?
Old Jan 16, 2007 | 07:32 PM
SlowCar's Avatar
Originally Posted by EvilBlueEvo8
Yeah. I'll believe it when I see it. Steve has been saying that since I got my kit in November of 05. Its always "a few weeks away". BS!
damn...this better be the mother of all failsafes!
really want to see what it is capable of!
Old Jan 18, 2007 | 05:42 PM
EvoTech's Avatar
Originally Posted by C6C6CH3vo
Check out Snow Performance. They got a $99 flow sensor that will send 12vdc out to, another product of theirs, a WG solenoid - $39 when flow drops below 378ml/min. So for $140 you get a failsafe system for your alcohol kit.
It is a real simple setup too, as long as the flow meter doesn't interrupt solvent flow or psi and can withstand anhydrous MeOH, and furthermore have to ballpark adjust the flow rate of 378cc/min for H2O/alcohol respectively to anhydrous alcohols.
Their product seems reliable too - however they havent really been introduced to the Evo community yet.
Integrating the snow safe injection with an SMC kit is not proving easy. The trigger for the SMC kit is a progressive ground and it will not work on a realy. The xext step is a pressure switch that will turn on the safe injection @ 15 PSI which is after the bump has begun to spray. I have high hopes for this design. I will let you all know how it works out.
Old Jan 18, 2007 | 05:45 PM
Ultimate CC's Avatar
Keep us updated Ed...
Old Jan 19, 2007 | 12:15 AM
Richard L's Avatar
The DDS3 has been used on the SMC system successfully, details below:
https://www.evolutionm.net/forums/sh...highlight=dds3
