Snow Performance questions and answers...
I just got my Snow Kit with all the upgrades the other day..
Waiting on my "CF" RMR Steering column guage pod to get here.
Install is coming in the next few weeks..
Will post pics. + info,and dyno numbers during the install.
thx DAN..
thx DAN..
SafeInjection™
Available Again! New Improved SafeInjection™- boost/timing reduction system for use with the Boost Cooler® water/methanol injection system promises to revolutionize the industry by providing for safety even with the most aggressive tunes.
The net result of much development and a complete redesign, the new, improved design answers the call for more features and reliability. For years, many have wanted to use water/methanol injection but have not taken advantage of the power increases do to safety concerns. Designed as an add-on to the Boost Cooler® water/methanol injection system, SafeInjection™ allows for a safe tune in those instances where no injection is present and an aggressive tune is utilized. “Water/methanol injection is great and our systems are engineered for reliability, but in the case where you run out of fluid with an aggressive tune, many want the peace of mind that this system provides.” says Matt Snow of Snow Performance. The new and improved unit has these important features:
1. Fully adjustable alarm set point with new electronics for versatility.
2. Retard Timing- detailed instructions on integrating with our MSD, J&S Safeguard, & other popular aftermarket ignitions.
3. Optional Solenoids to open waste gates or bypass valves to reduce boost.
4. Faster response time and can display real time flow in ml/min (with optional gauge or stage-3G LCD screen).
5. Overflow alarm for leak detection.
6. Completely new internals for robustness and higher function
Benefits:
• Ability to run extreme tunes and high boost with safety.
• Automatically reduces boost or timing if fluid flow insufficient.
• Easy installation.
Be sure and check out the available flow-gauges and wastegate and bypass valve solenoids!
Benefits:
Snow Performance is announcing the debut of the ultimate in water-methanol injection systems for gasoline engines.
The Gasoline MPG MAX™ and the Gasoline Stage 3 systems are the most advanced, and yet, easiest to use and dial in systems available.
1. 3 Dimensional Mapping. Amazing accuracy and flexibility.
2. LCD Screen displaying Boost, Fuel Injector Pulse Width, and Water-Methanol Injection %
3. Pushbutton adjustment and tuning
4. Ability to accurately inject in all load states - from very light throttle to full load, wide open throttle.
The Gasoline Stage 3 Boost Cooler® and Gasoline MPG MAX™ from Snow Performance, the Water-Methanol Injection Experts™. Available on or before December 1, 2008.
Stay tuned for more updates!
