Snow Performance questions and answers...
Old Oct 9, 2007 | 05:48 PM
  #601
Evoryder's Avatar
If you wait till saturday I could give some pointers on the install.
Old Oct 9, 2007 | 08:22 PM
  #602
diiirk@AwdMotorsports's Avatar
thanks for the input dan. am i pretty much on track with my install plans?
evoryder, if i did do it on saturday it would have to be early am, im getting tuned on saturday at machines gone wild. i took off work on friday, so ive got all day to install my fmic, licp, manifold, 02 housing and meth kit.
still not sure where the yellow wire from control box goes.
Old Oct 9, 2007 | 08:53 PM
  #603
Evoryder's Avatar
Can't help you then...
You're going to have a fun friday...hope you have gatorade and beer
Old Oct 11, 2007 | 11:12 AM
  #604
is it better to run the tubing under the car, or through the car under the door sill things. if through the car, whats the best way to get the tube into the car from the trunk, i dont know of a passageway from the trunk to the interior.
Are there any other misc parts i will need for the install. Drill bits, wires, anything?. Are the wires from the pump long enough to make it to the from of the car?
What exactly does the yellow wire from the control box tap into.
sorry for all the questions, im doing my install tomorow, and id like to have all parts ready before i start.
Old Oct 11, 2007 | 11:47 AM
  #605
Evoryder's Avatar
1. Did you not get an install manual?
2. "The YELLOW wire at position 2 is not used in boost referenced applications" You gonna use a boost solenoid? or the controller
3. I ran the line under my car next to the fuel lines when my setup was in the trunk(had the tubing in electrical plastic tubing for protection)
4. go to snowperformance.net and look under your kit, they have the install pdf.
Old Oct 11, 2007 | 12:37 PM
  #606
the instructions say that it connects to "Karman MAF sensor signal"
Old Oct 11, 2007 | 02:06 PM
  #607
Evoryder's Avatar
not sure which it is...
Old Oct 13, 2007 | 05:02 PM
  #608
dlabonte's Avatar
If you have one of my VC-25D injection controllers, the yellow wire goes to the signal output of your mass air flow sensor. It should be a White wire with red stripe. Karman Vortex is the type of MAS used on the EVO, it is frequency output.
If you have a volt meter you can test it somewhat. At idle will be high 4volt output. Rev the engine and voltage will go down some. A hot wire MAF, like used on Fords, is a straight 0-5volt analong output.
Best regards,
Dan
Old Oct 14, 2007 | 12:15 PM
  #609
Ultimate CC's Avatar
so did you get this all straightened out and installed?
Old Oct 14, 2007 | 12:20 PM
  #610
Evoryder's Avatar
^ u got my Pm?
Old Oct 14, 2007 | 01:30 PM
  #611
just responded to it...
Old Oct 14, 2007 | 01:36 PM
  #612
Evoryder's Avatar
TAG your it
Old Oct 14, 2007 | 07:51 PM
  #613
cpoevo's Avatar
Dan since you are the Snow expert I am running the Stg 2 with SI on 50/50 mix with a 500ml/min nozzle same type as Snow uses. I have the Zeitronix with failsafe as well. I am in CA so we crappy 91oct. What point should I start the inj and full on point. I am starting boost at 22psi and will work my way up to 25psi on the stock turbo.
Thanks
Old Oct 14, 2007 | 07:53 PM
  #614
I personally like to start spraying at around 13psi and ramp up to full by 22psi (reason I don't have 25psi as the max is that you only hit that boost for a short period and you really need the full spray anywhere from 22psi up...) but theres a ton of different opinions on this topic, theres some tuners that like to start it at around 18psi and ramp to 25psi...its really up to your style of tuning but for me on 91oct I would want it spraying earlier on...
Old Oct 14, 2007 | 08:16 PM
  #615
cpoevo's Avatar
I am running the VC-25 and the highest start point is 8psi I will give it a try and see what happens. My spoolup seems a little slow at like 5psi.
