Snow Performance questions and answers...
I wouldn't want to pull the amt of fuel required at 30 psi and only 900 hz when a pump kicks on sending 180psi of methanol through a 675 nozzle
i have only run idc and on/off injection, really like see some logs of progressive pump speed injection in action
A granny shifted 1 - 2 - 3 log:
same one without the clutter
i definitely did but my car went from great to dead shortly after...(not gonna get into it but had drivetrain rebuilt by a reputable company and it was a disaster in which I ended up getting rid of car and buying the vette)...
Slightly off-topic, do you guys think an AFR of about 11.3's is kind of conservative for meth and boosting 28psi? or does that seem fine depending on how aggresive the timing map is?
Yes 11.3 is conservative on my meth...do you have a failsafe? How aggressive is your timing?
