Snow Performance questions and answers...
Old Aug 26, 2007 | 09:12 AM
  #526
Ultimate CC's Avatar
Originally Posted by uSmC_08
Dan, please gimme a call bro! I wanna get the 2D kit off ya
i believe we talked already but if we didn't please let me know...
Old Aug 26, 2007 | 12:03 PM
  #527
Evoryder's Avatar
Dan did you get my PM?
Old Aug 26, 2007 | 05:40 PM
  #528
No, but let me go check again, if you wouldn't mind just pm me again (we have 3 working for us now so there is a chance that someone had opened it and didn't respond back but either way just resend if it you wouldn't mind)
Old Aug 26, 2007 | 08:26 PM
  #529
Cracing's Avatar
i am running the Snow Performance kit and i was wondering why my led light that indicates the kit is turned on turned a orange color as soon as the boost went past 10 lbs? Normally it lights green once past 10 lbs. but i have noticed a couple ttimes it will go to an brown/orange color instead
also other times the led wont even turn on So i dont risk it and immediately let of throttle.
is this due to a weak led? most the times it illuminates correctly
Old Aug 27, 2007 | 08:46 PM
  #530
how long have you had the led?
Old Aug 28, 2007 | 12:21 AM
  #531
Cracing's Avatar
maybe 2 or 3 weeks. i took it out of the car today and tested it and it was a faulty led wouldnt light up with 12v source. i guess there not rated for longer then a few weeks!
i replaced it with another brighter led and it works like a champ.
Old Aug 30, 2007 | 04:14 AM
  #532
C6C6CH3vo's Avatar
The new safeinjection will soon be out and I know for sure because the part has been running on my car for several weeks.
The new part is 60% the size of the former and uses a completely different mechanism than that of the old one, and the long wait for it's release, I find, was required for stability testing using anhydrous methanol, so my guess that is good.
The part I believe will be a subsystem for the new Stage 3 kit which I don't think is out yet for Evo's because I don't see it currently advertised at SnowP, duh.
Nevertheless, apart from my intuitive logic you have just witnessed, the new part is quite an improvement over the old SI05/10 (they were a PITA for me to adjust) when run on the current Stage 2 or 2D VC's systems (my setup has the VC 25). The fault trigger out is adjustable from 100ml/min to 500ml/min so there's no need for a delay as before. I have it set at 500 ml/min running a 675 nozzle and have not had any nuisance failsafe triggers yet which was the main problem I had with the old style, and 500ml/min is a good margin of safety.
I guess I can post pictures later
Old Aug 30, 2007 | 04:04 PM
  #533
1evo4me's Avatar
Originally Posted by Ultimate CC
I am here to answer any questions about Snow Performance kits...
Hey, what is the flow rate of the 375 nozzle in gallons per hour?
Thanks
Old Aug 30, 2007 | 05:45 PM
  #534
cpoevo's Avatar
Its just under 6gph. Go to this site and you can see the nozzle sizes and what the equal is in gph and ml/min. Just look at the drop down box for flow rates.
http://www.coolingmist.com/detailmain.aspx?pid=13N
Old Aug 30, 2007 | 08:58 PM
  #535
evokel's Avatar
just a stupid question... could you run the stage 2 on stock turbo?
Old Aug 30, 2007 | 09:24 PM
  #536
certainly...i ran the stage2 on my stock turboed evo for over a year...its a great combo...
Old Aug 31, 2007 | 06:20 AM
  #537
C6C6CH3vo's Avatar
Don't forget that you can't tune your car right and it's not safe with any other system other than aguamist, and they're affordable too.
Old Aug 31, 2007 | 06:35 AM
  #538
SlowCar's Avatar
The price of a 2D pump speed system is ~30% to ~50% more than a simple on/off injection system.
What is the benefit of running a 2D pump speed system vs. a simple, predictable, lower cost on/off injection system?
Old Aug 31, 2007 | 10:56 AM
  #539
Evoryder's Avatar
We shipped the nozzle yet :P?
Old Aug 31, 2007 | 11:19 AM
  #540
1evo4me's Avatar
Thank you for the info!
