I already have a base flash. Do I need another tune for Alky?
Old Apr 4, 2006 | 03:50 PM
KY's Avatar
KY
I am getting an Alky kit, but I was curious if I needed to get tune before I turn up the boost. I am trying to hold 25psi with the SMC kit. Al dynoflashed my car already for intake and stuff, just wondering if I need another tune to adjust A/F.
Thanks
Old Apr 4, 2006 | 08:33 PM
Ultimate CC's Avatar
yea you do
Old Apr 4, 2006 | 08:56 PM
SR20DE-T's Avatar
You dont need to post in two places..
Old Apr 5, 2006 | 08:13 AM
TTP Engineering's Avatar
Your power gains will be realized in proper AFR's for the volume of meth you are spraying and the ignition timing numbers you should run on meth injection of sufficient volume.
Old Apr 6, 2006 | 05:13 AM
C6C6CH3vo's Avatar
+1
Spraying methanol untuned may allow 3 - 4 psi higher boost but it will be too rich and won't add much. The main reason to use methanol is to be able to run powerful timing and boost without detonation.
Old Apr 7, 2006 | 01:50 PM
flabarm's Avatar
So he could get another flash for the alky and would be ok?
malonejr2000
Sep 24, 2009 04:26 PM
Barrett006@aol.
12
Jun 3, 2007 07:12 AM
mapleleafevo3
Dec 10, 2006 05:26 PM
justchil
Jun 22, 2006 10:46 AM
Sean@Iveytune
Automotosports - Illinois
77
Oct 25, 2005 11:36 PM
