SMC & Aquamist DDS integrated...finally done!
Originally Posted by evodave
great work for sure... good idea. I might have to do somethign like that IF i keep the SMC setup on my car. I will say that the SMC control boxes go bad so as long as that little black box is in there its not foolproof....definitely a good addition to have though cause even with knock control on and other tricks we couldn't stock piston damage last year cause of it.
aresix6,
I have just managed to cut and paste your wonderful write-up of the DDS3 install onto the aquamist site, no less than 107 images+ text!!!
It must have taken you hours to organize the contents in the first instant.
Again, a big thank you.
Richard
Richard
Hey Richard...jus one quick note I forgot to mention in the write up that's more of a contructive criticism/possible product improvement. On the actual DDS3 monitor that fits in 52mm pods, I kind of felt it would be slightly more advantageous if there was a way to unplug the wires from the back, you know, like a plug in behind the gauge. In order to do any future maintenance or to take it out or if it ever needs to be removed, it has to be completely unwired from the brainbox, rerouted back thru the center-console/dash area and pulled out. I guess that's more of a "gee-whiz, I'm lazy" thing, but just food for thought. Not sure how feasible or cost effective that would be though for Aquamist.
Aresix6,
Thanks for your comment and improvement on the construction of the DDS3 gauge.
I agree with you entirely. On the next version, we will put a connector on the back of the gauge. Meanwhile you can always allow extra cable length behind the cable so it can be taken out for inspection. A connector will make total detachment very simple.
I always welcome comments regarding our products, bad or good.
Richard
Richard
can just make your own connectors. cut the wires behind the gauge (with some distance between the gauge and the cut and not right up against the gauge!) and use male/female spades to put the connection back together. then you can undo them as many times as you need.
DDS3 to MBC wiring
Originally Posted by damianhindley
How could this setup be done on a car with a manual boost controler? Could i still power the stock unit to kill the boost? Or are you using the exde to do it?
Here is the basic DDS3 wiring diagram to achieve this (ignore the aqumist pump set up):
If you to follow through the entire thread on how it works, please use the following link:
http://www.aquamist.co.uk/phpBB2/vie...+valve&start=0
You may need to register first
Richard
i used a 3/2 NO MAC 36 series solenoid valve for the above
http://www.macvalves.com/Catalogs/NT/36.pdf
very fast reaction time. Turbosmart use MAC solenoids valves in their EBC
aresix6, I re-read your intallation and have to give you many props once again. I overlooked the part that you used the Xede and the factory boost control solenoid like I did a while back. Clever minds think alike
Last edited by EvoTio; Jun 3, 2007 at 12:51 PM. Reason: spelling and clarification of my answer
