torn between these alky kits. help
Originally Posted by Ultimate CC
The snow peformance kit with safeinjection is the best bang for the buck...I had smc and sold it for many reasons, couldn't be happier with the snow performance kit...
What happens if a car is tuned on a 7gph-441cc/min or bigger nozzle........15gph-945cc/min and the nozzle develops a "minor" clog BUT still able to flow above the setpoint, ie flow is greater than 378 but lower than 945.......
The aquamist dds3 has a user definable "safe operating window", 2 setpoints, a lower and a upper flow setpoint, outside of this window will trigger the failsafe.
I also agree with SlowCar. As I mentionted before, Aquamist is the pioneer of failsafes. They are ahead of their time in the relation to the failsafe concept. I'm not saying that the others will not eventually "catch up", but Aquamist has been the best in the past and at the moment. I'm glad more people are finally paying attention to wanting failsafes incorperated in their water/alcohol set ups.
The SMC may have no failsafe yet, but considering there are over 500 kits being used on evo's in the US I think its doing pretty well. I've only heard of a few cases here and there of people blowing motors on SMC kits and those cases were on the V1 kit.
there are potentially 500 customers out there sitting on a time bomb....tick tick tick.......
The more and more I see about water injection, it's all hype!!! The whole "it's water, it's safe for your car" is bullpoo
As many cars that have blown up over the last couple of years on it, you would think people would just use Nitrous instead and get some real power and be just as "safe" as water/methanol injection.
just my $.02
I know 5 locals all who have had atleast one pump fail, the people they have them last forever are the ones that barely use them, I have over 50 gallons of methanol through my evo on my snow performance kit and its still going strong...
the smc kit uses a flojet pump designed for 35psig usage........failure IS no surprise when they are pushed to 80-100psig.
the shurflos pumps on snows/ams other hand are made to run 100psig, all day long, all day strong
I have the Snow Performance kit with the Safe Injection and I couldn't be happier. Just for point of reference though a stronger pump doesn't do you any good unless you're pushing rediculous power... in fact you don't want a ton of alky/meth in the engine at all. According to Al when he tuned me with the kit this last weekend too much meth/alky isn't great for getting a good tune. A 300 psi pump is overkill... 150 shoud be all you need for the EVO.
the more methanol the better! the only downside is if your system screws up, so will your car
the higher the pressure, the better the atomization. Why is a 300psi pump overkill?
