Battery In Trunk Plus Meth Tank?
Old Aug 24, 2006 | 10:11 AM
EvilBlueEvo8's Avatar
Is it safe to have a battery relocated to a trunk with a meth tank? I'm just thinking of what would happen with an accident or what not. I guess it wouldn't be worse than the regular gas tank, but what do you guys think?
Old Aug 24, 2006 | 06:20 PM
anyone?
Old Aug 25, 2006 | 02:09 AM
Fusion7's Avatar
Just secure everything really good and tight. If you really want make sure coat the meth tank wit ha flame retardent or something.
Old Aug 25, 2006 | 02:41 AM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
If you put the battery on one side(right) and tank on other, you should be fine.
Old Aug 25, 2006 | 08:00 AM
C6C6CH3vo's Avatar
First of all both have unrelated risks and one related hazzard. Especially if in poor repair - a battery emits H2 gas (remember hindinburg) and trunk mounted units need ventilation ducting.
The methanol reservoir is like anything else you put in the trunk - if it leaks then all you need is a spark (loose battery terminal!) the fumes will ignite the liquid so again the need for ventilation is required.
Worse case scenario:
-leaking methanol tank
-loose battery leads
-battery emitting Hydrogen gas
Get a fire extinguisher, hell, I need one too
Old Aug 25, 2006 | 10:13 AM
thanks guys. with regular maintenence checks, there doesn't seem to be an issue then. especially with both properly installed
Old Aug 26, 2006 | 06:25 AM
SlowCar's Avatar
Fire = oxygen + fuel + spark
oxygen - 21% of it in the atmosphere
fuel - methanol vapor
spark - from the brushes/commutator of your injection pump
If concentrations of fuel vapors is allowed to build, especially in the trunk of your car, seems to be a recipe for a fire.
Old Oct 19, 2006 | 07:44 AM
maximumpsi's Avatar
Another thing that is often overlooked:
When methanol burns it is invisible. You can have a fire and not even see it until you see things visibly burning/charring. If you plan on setting up a meth system in the trunk with a larger tank, etc, it is a worthwile investment to look into a fire system for the car. Chances are you have some decent money invested into your modded car anyway, and this gives you some added protection in case the unmentionable happens.
Old Oct 19, 2006 | 09:41 AM
EVOLVEU's Avatar
this is true with a wet cell battery. dry cells, such as optima dont have that issue. mitsu recommnends them for our cars. you shouldnt have any issues, i dont and thats my setup. ill take pics if youd like.
Old Oct 19, 2006 | 06:49 PM
thanks for the responses guys. i'm going to put a small extinguisher on the harness bar i think.
GreeceS13
10
Mar 9, 2017 06:37 AM
ryukinevo
Nov 13, 2015 12:00 AM
real fast
Nov 30, 2012 08:19 PM
momofx
11
Jul 28, 2011 03:34 PM
CtSilver03Evo
Jun 23, 2011 09:03 AM
