Keeping methanol suspended in water/meth mixes
Righto,
I've got a Meth/water setup. I am running 50/50 at the moment but notice that the water and methanol are separating in the injection tank.
Does anyone use a wetting agent to keep the two homogenous ie detergent/surfactant? Suggestions are welcome!
Does anyone have the same problem?
Before anyone says run 100% methanol, I don't want this setup, I am after 50/50.
Looking forward to some good advice here.
cheers
Matt
cheers
Matt
Yes that is correct it does mix. The methanol I bought was contaminated by the chemical blending company. I am still waiting for them to sort this out as it has caused a problem in my kit. I am now running ELF methanol and it mixes beautifully with water.
I usually buy the Yellow Heet bottles at 97c for 12 oz, I filter it though. It is at least 98%
The CAS# for methanol is 67-56-1
Sorry to hear you got some bad liquid, hope you get it cleaned
So, for instance... what if you run out of alky, and go into boost. Will the ECU pull timing for saftey?
Next question is, has alky been tested over a long period of time? what are the effects on engines? I will be driving my EVO daily, I like to spool the turbo frequently. its the injection triggered by a certain amount of boost? I am having a hard time understanding how the systems work. I understand what meth/alky does @ combustion. Can someone elaborate?
Next question is, has alky been tested over a long period of time? ?
