what bov are u guys running w alky?
just picked up the cooloing mist alky kit. wondering wat bov ur using. im currently running the jdm mr bov but i dont think she can handle all the boost. i heard itll leak after 24psi. i might end up ordering the aps valve even though its on 3 week backorder.
i have herd it will hold 28-30psi but if you want to get a new one for reassurance you should get a forge RS recirculating bov i have been told it will hold 38psi on the hardest spring! are you running stock ECU? if so you have to recirculate for the car to run right
no, ive been running the turbo xs utec. people rag on it but it really is the ultimate ecu. but anyway, yeah everybody says diff things, i was told by 2 guys at the local speed shop that its gunna leak after 24lbs. i hope not cuz im goin to turbotrix in jersey to get a map for alcohol, but if im leaking boost, there cud be a problem
Originally Posted by c-los
jdm mr bov ...
It will handle all the boost you need. I have the first gen DSM valve that is a similar design to JDM MR one and it's hold everything just fine. I let it spike to 30 PSI on 93 octane and Methanol.
Just get it tuned correctly.
Are you guys a bunch of advertisers? Just run the JDM MR bov and if it starts to leak, then crush it (yes you can do this on it too) and then if it leaks after than, then buy a new one. Don't buy something if it's not absolutely needed yet.
Originally Posted by Mivecless
You don't want any VTA valve with meth, unless you want the fuel all over the engine bay.
