Failsafe for buschur /smc meth injection??
Old Sep 25, 2006 | 07:51 PM
BoostWhore's Avatar
IM wondering if anyone knows if there kit has a failsafe singal wire which could be used to trigger something if it fails thanks
Old Sep 26, 2006 | 09:25 AM
BoostWhore's Avatar
up
Old Sep 27, 2006 | 05:06 PM
BoostWhore's Avatar
anyone know anything?
Old Oct 11, 2006 | 06:27 AM
GTVEVO's Avatar
Yes do a search it has been covered many times, there is a pump pressure switch built into the pump that is either grounded or feed 4.5 volts when the pump has 40psi or more, you can add as many for like pressure as you need or one into the line for over pressure (nozzle clog) if you want.
I believe that SMC was in development of a kit with a safegaurd built in but I don't know if it was ever released you could find this in the search as well probably.
drsrock
Feb 11, 2015 12:19 PM
Grimgrak
Nov 29, 2013 03:06 AM
Thatotherguy
Apr 20, 2013 03:52 PM
saulbyu
15
Jan 21, 2010 11:00 PM
NIevo
49
May 13, 2007 10:54 AM
