controller problem
controller problem
i have the buschur racing alky with the smc controller and when i hit boost it does not light up the spray light. but when i push the test button it will light up and spary. i turn the boost down from 26psi to 20 psi. the boost line for the controller comes right off my boost gauge. the controller is set up to spay at 17-22 psi (progressive) anybody have any idea how to fix this?
ok, so i did a little more testing and found out that the spray light doesnt come on till the pump hits 30 psi. so i had a buddy watch the gage and i was only hitting 30 psi for a split second and then around 15-20 psi. so its probally a pump problem. anyone know how to fix it or do i need a new pump??
get in touch with steve @ smc. he'll help you.
schlupsa31@mchsi.com
Steve Chlupsa
SMC Enterprises
www.smcenterprises.com
270-522-9376
Steve Chlupsa
SMC Enterprises
270-522-9376
Originally Posted by hawaiievo
talked to steve and he said that i need new pump seals. and that they were covered under warrenty!!
He's provided some good customer service. Glad to see you found out what the problem was.
