What kind of TUBING for Snow Performance Injection
Old Feb 22, 2007 | 09:12 PM
mcwoowoo's Avatar
I bought the Snow Performance Kit and I'm trying to locate the bottle and pump inside the trunk. However the Nylon Tubing that came w/ the kit is not long enough. The spec of the tubing is: NYLON 1/4"OD, 0.040" Wall thickness, 400PSI at 70F.
I can't find the same kind of tubing anywhere. Any suggestion on what tubing I should use to replace this Nylong Tubing? and where to buy?
Old Feb 22, 2007 | 09:14 PM
Ultimate CC's Avatar
I can ship you out more if needed, all my customers I send atleast 20ft...you may be able to source it cheaper locally though...
Old Feb 22, 2007 | 09:17 PM
mcwoowoo's Avatar
I checked Homedepot and they only have the same size of tubing w/ 140PSI at 70F. will that work just fine? or will it blow up?
Old Feb 22, 2007 | 09:20 PM
SlowCar's Avatar
dont use those, polyethylene tubes will balloon
Old Feb 22, 2007 | 09:21 PM
mcwoowoo's Avatar
thanks for the quick reply.
btw, how much will it cost if I want to buy about 20ft from you and have it shipped UPS Next day or 2nd day?
Old Feb 22, 2007 | 09:23 PM
pmed..
mcwoowoo's Avatar
LoL, I was looking inside my car all night trying find a place to mount it, but still can't think of a good place. So it has to go in the trunk..
Old Feb 22, 2007 | 09:25 PM
yea our engine bays are very tight, even with a mini battery...
Old Feb 22, 2007 | 09:26 PM
mcwoowoo's Avatar
Ultimate CC, thanks. Please check pm
Old Feb 25, 2007 | 06:58 PM
Checked, sorry was away for the weekend...
Old Mar 2, 2007 | 09:59 PM
Dapper Dan's Avatar
i bought some tubing from home depot....2 months and no problems here.....
Old Mar 3, 2007 | 05:19 AM
SlowCar's Avatar
depends on the length of tubing between your pump outlet to the nozzle, it will increase run-on volume. the polyethylene tubing from HD is not meant for high pressure and will "balloon"
insanum
Nov 11, 2023 05:16 AM
RyanD3
Mar 8, 2016 02:37 PM
Kustom09art
Southeast Region
Oct 30, 2015 04:28 PM
Jrah2987
13
Jul 5, 2013 12:18 PM
AMSTuning.com
Mar 22, 2005 06:23 AM
