Meth tank time limit.
Old Apr 19, 2007 | 07:56 PM
  #31
dubbleugly01's Avatar
Originally Posted by SlowCar
the only 2 things that will happen
-methanol evaporates
-methanol adsorbs moisture from atmosphere as it is hygroscopic
methanol will oxidise aluminum and zinc(from brass fittings) and form a whitish precipitate of oxide/hydroxide at the bottom of the tank - keep those away from methanol tank
what do you think about a zinc anode bolted to the aluminum intake for corrosion protection? Has anyone tried it yet?
Old Apr 20, 2007 | 05:12 PM
  #32
SlowCar's Avatar
both the Zn and the Al has to be submerged in the medium for sacrificial anode cathodic protection to occur...almost have to Zn plate the Al intake
how about impressed current cathodic protection?
Old Apr 20, 2007 | 10:40 PM
  #33
fromWRXtoEVO's Avatar
http://fluids.flambeau.com/
any shape any size for cheap
Hey Abner,
I would be very interested on a ***** shape water tank.. Could you find me one for cheap ? Just kidding man.
On a serious note, you went overboard with the quantity Abner, I am still using the one gallon with the number #7 nozzle and it last typically 3-5 gas tank and I am on full boost several times a day going back and forth to work.
Definately I totally agree with you about the determine factors of methanol/water/alcohol usage.
Carlos
Old May 23, 2007 | 03:34 PM
  #34
bioman's Avatar
If I used a 4 or 5 quart replacement tank for my snow stg. 2 kit, which specific one would I have to get? Also, does anyone know what other fittings, hoses, etc I would need to directly hook up to the pump? Thanks.
Old May 28, 2007 | 10:15 AM
  #35
SlowCar's Avatar
you want to get a tank that is tall and narrow...lessen the chance of liquid with sloshing around and air getting into pump intake
Old Aug 22, 2007 | 08:56 PM
  #36
Adam@MMS's Avatar
So for a 20 minute road course open track session, spraying an average amount of meth, how big of a tank would one need? Roughly.
Old Aug 23, 2007 | 06:44 AM
  #37
Adam@MMS's Avatar
bump
Old Aug 23, 2007 | 07:20 AM
  #38
Adam@MMS's Avatar
Gonna answer my own question. Sorry. Hopefully someone finds it useful. I just looked at my logs and for Lime Rock park which takes about a minute ten for me to get around, I am WOT for 27 seconds. So for a 20 minute session that's about seven minutes of WOT. So based on the calculations in the posts above and with a medium sized meth nozzle (600) I am guessing I would need about 6 quarts at the minimum and 8 to be safe. Looks like the stock front washer tank isn't going to cut it unless I use a very small nozzle (like 400).
Also, just FYI, Snow performance has 4 gallons of 50/50 methanol mix for sale for $25 on their website, used to be $45. Seems like a decent deal.
Old Aug 23, 2007 | 07:51 AM
  #39
SlowCar's Avatar
you want to go bigger/more tanks rather than smaller nozzle
18 quarts setup:
mix your meth/water, 5 gal drum tech grade meth ~$30, distilled water from grocery
Old Aug 23, 2007 | 08:30 AM
  #40
Adam@MMS's Avatar
very nice. I can't use regular tap water to mix?
Old Aug 23, 2007 | 09:03 AM
  #41
SlowCar's Avatar
tap water has undesirable minerals that might clog up the orifice of nozzle, distilled water is better for this application
Old Aug 23, 2007 | 07:07 PM
  #42
CO_VR4's Avatar
I use heavy water, from Norway, for its atomic energy potential.
Old Aug 23, 2007 | 08:12 PM
  #43
not to mention this setup will give you a better weight distribution and aid in a bit less understeer
18 quarts setup:
Old Aug 27, 2007 | 08:48 PM
  #44
Ultimate CC's Avatar
yea thats a whole lot of meth in the trunk...very clean setup...
Old Dec 27, 2007 | 02:14 AM
  #45
TheRealSpdFreak's Avatar
18 quarts setup:
On here because I like reading the water/meth/alcohol injection forums. Great forum!
I saw several places listed in this thread on where to buy tanks, but where can I get those specific tanks?
