NEW Snow Performance Safeinjection Q&A...
Old Apr 11, 2007 | 01:51 PM
  #31
SnowTech.3's Avatar
Originally Posted by SlowCar
15gph/945cc/min nozzle, its possible to calibrate the flow sensor to read
0vdc = 0 flow
5vdc = full scale 945cc/min flow?
You don't have to calibrate the output signal or gauge - you simply hook the gauge up to the output wire from the new Safe Injection, and it reads in ml/min. Yes, it's that simple. No calibrating, no nothing.
Old Apr 11, 2007 | 01:53 PM
  #32
SnowTech.3's Avatar
Originally Posted by Ultimate CC
New Improved SafeInjection™uses a flow meter to indicate flow rate and now comes with an adjustable trigger flow level.
I will have pics of the new unit shortly...
Also - there is a built in "overflow" alarm as well, incase a large leak occurs, etc.
Old Apr 11, 2007 | 01:58 PM
  #33
SlowCar's Avatar
do you have a VDCout vs. flow rate plot for this flow sensor?
Old Apr 11, 2007 | 09:20 PM
  #34
C6C6CH3vo's Avatar
Tubing arrived Snowtech3, thanks. New failsafe unit will be installed this weekend. Unlike last two weekends
It wont be a stage three that flows via IDC, just a MAF/psi with new failsafe and simple flow guage
Old Apr 11, 2007 | 09:25 PM
  #35
Ultimate CC's Avatar
nice...
