Faisafe's with the SMC kit?
Old Mar 23, 2007 | 07:07 PM
SlowCar's Avatar
Originally Posted by TTP Engineering
But, then you misdirected 6 hours ago.
https://www.evolutionm.net/forums/sh...04&postcount=6
Old Mar 23, 2007 | 07:50 PM
SlowCar's Avatar
I am not a believer in the flow sensor to be honest. I find it to be a poor failsafe as partial leaks or clogs can circumvent the failsafe. The AFR/EGT/BOOST/TPS failsafe is as rock solid as they come. It is nice to know that those that are looking for yet another layer of some kind of protection, have that option ALSO with the ZEITRONIX units.
Aquamist dds3 standalone = excellent failsafe
Zeitronix zt2 standalone = excellent failsafe
when you combine the 2, the car would not have to reach high afr/egt to trigger failsafe when there is a injection fault - bulletproof
leaks and clogs is what the flow sensor detects best
Old Mar 23, 2007 | 08:54 PM
NIevo's Avatar
Originally Posted by Richard L
I didn't realise the Zeitronix costs only around $100 with wideband.
This has to the cheapest fasilsafe around to monitor afr.
If flow sensor and egt probe is added, how much more do you have pay?
Well I already have the wideband for tuning purposes. To add the failsafes is another $100 or so. The egt probe is $77, not sure about the flow sensor.
TTP, so is there a write-up somewhere on how to install everything?
Old Mar 27, 2007 | 06:15 PM
tobz's Avatar
TTP, so is there a write-up somewhere on how to install everything?[/quote]
Old Apr 2, 2007 | 10:52 AM
elhalisf's Avatar
I will be doing the same type of fail safe for my car. Whats the point of a fail safe if it cant measure the end result, ie. AFR, EGT, etc...
moreover, the zt-2 fail system can be used as a general purpose fail safe, such as high EGT's with bad gas, High Boost with leaks in the MBC lines, Lean AFR with an injector failing, etc.
I already have the zt-2, so the add on alarm and relay are very cheap.
Old Apr 2, 2007 | 10:54 AM
elhalisf's Avatar
For the safeguards and audio/visural warnings, yes. For boost cut we have a special solenoid also for this purpose.
can you explain more about this solenoid you have and its cost? I was about to use a spare EGR soleniod i have because i couldn't find anything that will trigger open with a 12v signal.
Old Apr 2, 2007 | 03:10 PM
Richard L's Avatar
Will you be running 100% meth?
Old Apr 2, 2007 | 03:36 PM
NIevo's Avatar
Who are you asking? If me then yes.
Old Apr 2, 2007 | 04:12 PM
elhalisf's Avatar
me as well....
Old Apr 2, 2007 | 06:52 PM
Richard L's Avatar
sorry, anyone who runs wideband as failsafe.
Old Apr 2, 2007 | 06:54 PM
elhalisf's Avatar
please tell me your thoughts of running a wideband as a fail safe.
Old Apr 2, 2007 | 07:07 PM
TTP Engineering's Avatar
ZEITRONIX is not a wideband. It is a hardcore tuning partner complete with EGT, AFR, MEDICAL GRADE PRECISION PRESSURE TRANSDUCER FOR BOOST MEASUREMENT, RPM, TPS, LOGGING, MITSULOGGER AND EVOSCAN COMPATIBLE. Furthermore the ZAVT (Zeitronix Audio-Visual warning and safeguard trigger) is state of the art and virtually makes a this safeguard bulletproof.
Did I mention that there is even a trigger and alarm for a flow sensor input?
I am excited that Zeitronix leads the way for meth injection users with their amazing multi angled protection system.
Aquamist should be taking notes.
Old Apr 2, 2007 | 07:24 PM
NIevo's Avatar
Just curious but how do you wire it for flow sensor input or is that in the instructions? Mine should be here in 2 days!
Old Apr 2, 2007 | 07:27 PM
elhalisf's Avatar
no you did not! elaborate please.....and about the boost seloniod.
Old Apr 2, 2007 | 07:30 PM
elhalisf's Avatar
OHHHH, you can use a flow sensor in the lines that will output the pressure in the lines to a 5V signal. that can be used for the User input on the Zt-2!!! correct? How much do you sell the flow sensor and the boost soleniod for?
