Faisafe's with the SMC kit?
OK this is what I got from Scott / TTP (Thanks a ton Scott!):
Relay for Boost Solenoid
red= 12v, blk 12v, green =solenoid, blue = unused, white= zavt output
Boost Solenoid
Basically you need (2) T's -- one on the inlet side (one to solenoid and one to MBC) and then one T on the WG side (from solenoid and MBC)
I currently don't have an EGT probe, but will get one in a bit. I would like to run the car at ~28 psi (peak) on either 100% denatured Alk or 75% Meth / 25% h2o (still contemplating). That said, I think the ZT2 could act as a failsafe monitoring AFRs and Boost. So now my question to folks running similar setups:
(1) What alarms have you setup ?
(2) Do you think a basic if Boost > 18 psi and AFR > 12 would suffice ? (I thought about adding TPS in the mix, but thought it would be redundant.)
Thoughts?
Thanks again TTP!
Boost Solenoid
Thoughts?
Thanks again TTP!
i believe you should only go 100% meth, do not mix that with water. if you are going to use alky, mix that with water.
plus, for me, meth is sooo much cheaper. i get it for $2.87/gal
i did my ZT-2 settings for >22psi, >95% TPS, >12.0 afr. the alarm sometimes goes off in first or second gear pulls (hits 12.1-12.2) when it was tunned for 11.5 afr on 3rd gear.
i suggest that you wire in only the alarm at first, to see how often it goes off.
so in regards to buying a alchy kit without failsafe if you have zt-2 is a good idea?
Also, what would be needed to run the zt-2 as a failsafe?
Just the ZAVT-1?
I already have the zt-2, boost solenoid, and pocketlogger w/pda
Just the ZAVT-1?
wizzo 8
Sep 10, 2009 11:58 AM
90GSXDan
Jun 22, 2008 09:10 PM
