Selecting Nozzle Size (Aquamist)
Old Apr 5, 2007 | 01:38 AM
giangi's Avatar
I just purchased a HFS-5 kit here in Italy, and now i'm going to fit it in my car, i have 1150 cc injectors, assuming to use a approx percentage of water/meth of about 20% in relation to fuel, what could be a good solution in terms of nozzle size, and even, is it better to fit one single nozzle or i should put 2 of these?
One last thing, for better atomization and performance, what's the best location for the nozzle(s), near the intercooler output or the throttle?
Thanks....
Old Apr 5, 2007 | 06:47 AM
dudical26's Avatar
Originally Posted by dubbleugly01
keep in mind a cc of fuel isn't going to be equal to a cc of meth when it comes to a/f ratios. So you can't really cut fuel delivery by 537.6 cc's, and make up 537.6 cc's of meth spray and expect a/f's to be equal between the two.
Yea I know, but I can still aim for 20% meth
Old Apr 7, 2007 | 05:28 AM
eve-slow's Avatar
Originally Posted by Richard L
Yes, use a Y-piece.
Keep the two jets about 6 " apoart if possible.
Yes, the "Y". Its gotta flow.
Also, how many people do you think are spraying a jet before the intercooler and one before the tb?
Old Apr 9, 2007 | 06:05 AM
Richard L's Avatar
We have always been recommending putting jet immediately after the intercooler but how many actually did, I do not know.
Old Apr 9, 2007 | 06:10 AM
cij911's Avatar
Richard -- Would you recommend just one nozzle right after the intercooler? Or would you recommend one after the intercooler and one before the TB? Most of the people I see are running just one nozzle right before the TB. Thanks
Old Apr 9, 2007 | 06:48 AM
Richard L's Avatar
If inlet tract cooling and even cylinder distribution is important, then placong the jet as far away from the TB will achieve the result easier.
Long path promotes better induction cooling and at the same time, droplet size gets smaller as evaporation takes place.
I would rather suggest placing two jets about 6" apart soon after the intercooler for one large jet after the intercooler and four small jets for each runner for in-cylinder cooling.
If you have problems finding a hard pipe to put the jets, here are a few options:
Old Apr 9, 2007 | 01:24 PM
Richard L's Avatar
Thanks....
Judging by the size of your injectors, I think you need to run two jets. Somewhere near the exit of the intercooler, 150mm apart.
You wioll probably need to take some fuel out or you will be running too rich. What is your maximum duty cycle with those injectors?
Old Apr 9, 2007 | 10:28 PM
giangi's Avatar
Thank you very much for your answer, as regards the jets i was thinking about using the 2 bigger ones that come with hfs-5 kit, the 0.9 and the 1 mm, for the location ok, 150 mm after the intercoller exit is not a problem.
About the duty cycle, actually i can't say, with my previous setup with gt35r turbo and stock head with hks cams i was about 70/75% max, but now with a GT4094R and a race head, with high lift tomei cams i think duty cycle will be higher, but i'm still finishing the engine, i have not certain numbers....
Old Apr 13, 2007 | 03:39 PM
MrEvo2U's Avatar
Richard,
Those solutions for installing the jet look very clean. Where can I buy those fittings? Also, if you install the nozzle near the exit of the intercooler; will some meth be recirculated through the turbo through the bov (assuming recirculated) when you shift?
shaman
Mar 13, 2016 10:42 AM
Richard L
149
Feb 27, 2016 03:01 PM
Sevolution
Nov 4, 2012 01:21 AM
EvoTio
35
Jul 24, 2010 12:34 AM
Darkn3s
30
Jun 1, 2010 07:14 PM
