NEW Snow Performance Mounting Adaptor and Bungs
Old Apr 8, 2007 | 02:40 PM
Ultimate CC's Avatar
Nozzle Mounting Adapter
NOW AVAILABLE! Need a way to mount your injector nozzle into your silicone or rubber intake tube? Snow Performance now offers a Nozzle Mounting Adapter for those without metal intake tubes.
Made from Delrin, the adapter is methanol resistant and highly durable. Installation is easy: simply drill a 3/4" hole using a spade bit, insert the inner adapter piece, and thread on the outer adapter nut.
Nozzle Mounting Bung
NOW AVAILABLE! Weldable theaded bungs make installing your inector nozzle easier when using thin-walled intake tubing. Simply drill a hole in your intake tube and weld in the bung. Your nozzle then has a strong threaded connection that can be used with confidence. Available in steel or aluminum.
1" diameter, 1/4" thick, 1/8" NPT threads for Snow Performance Boost Cooler nozzle. Can also be used with nitrous nozzles, boost port fittings, etc.
Old Apr 9, 2007 | 09:39 AM
The Devils Z's Avatar
** Bump **
Old Apr 11, 2007 | 08:30 AM
first shipments left today...
