General meth questions.
Old May 9, 2007 | 08:59 AM
ryan0's Avatar
What are the benefits of running a mix? Why not run pure meth all the time?
Is pure meth more corrosive on any parts in the system?
How quickly does it evaporate from the tanks?
How much would i have to worry about vapor? Even if its vented outside the car?
I want a set it and forget it system.. semi-large tanks.. something i dont have to worry about every day.
Old May 9, 2007 | 10:47 AM
Ultimate CC's Avatar
Do a search there are several threads that go for pages on the debate of different mixtures...lots of different opinions, I personally like 50-75% but others swear by 100%...its really up to you...evaporation really takes a long time if the container is sealed well like the stock washer tank or any of the tanks the kits come with....the biggest issue would be with 100% where it absorbs water and because less pure...
Old May 9, 2007 | 12:32 PM
inco9nito99's Avatar
100% water has the most heat dissipating ability.
100% methanol has the most octane boosting capability.
Windshield water is essentially 49% alcohol/49% water/2% dye.
Most power= 100% Methanol. Methanol also has a steam-cleaning effect, getting rid of any left over carbon deposits. Those who've ran methanol and have pulled their heads, their heads come out looking SPOTLESS -just an added benefit.
2% dye in the windshield water is pretty much just garbage you're injecting into the motor.
I've personally ran 100% methanol on my Eclipse with my DIY kit for the past 4 years on a STOCK motor minus cams/head studs/gasket with an m15 nozzle at 28-30psi at a safe a/f and timing and have had ZERO issues washing the cylinder out or any other negative effects.
Old May 9, 2007 | 03:04 PM
Richard L's Avatar
The thread below has some information related to your questions.
https://www.evolutionm.net/forums/sh...d.php?t=222680
Old May 9, 2007 | 04:39 PM
Saenek's Avatar
100% meth is also corrosive to aluminum, and some rubbers, etc.
