running meth...tune needed?
Old Jul 30, 2007 | 04:26 PM
Sti THIS's Avatar
is it mandatory to have meth injection and not run a tune? will you see any gains from meth without a tune? is it a 'must' or a 'should'?. thanks in advance.
Old Jul 30, 2007 | 04:34 PM
TxEvo8's Avatar
It is a must if you want to keep your engine running..
Old Jul 30, 2007 | 04:42 PM
prostcj's Avatar
You could probably run it at the same boost without a tune but what's the point of that?
Old Jul 30, 2007 | 05:08 PM
EVIL MR's Avatar
Must. Go hereVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVvvvv
Old Jul 30, 2007 | 05:30 PM
Sti THIS's Avatar
so i prob wont see any difference if i run the same 20 psi as i am running now?
Old Jul 30, 2007 | 05:40 PM
Boltz.'s Avatar
FCOTM Winner
You really need a tune for meth.
The meth acts as an octane booster and is burned as fuel. Think of adding meth without a tune like running 100 octane and adding a lot more fuel. You would never put injectors on a car and not tune it so the same goes for meth.
What are you thinking about doing? Why would you like to avoid a tune?
Old Jul 30, 2007 | 05:46 PM
SlowCar's Avatar
you will...you go slower due to overly rich-slow-cold combustion
Old Jul 30, 2007 | 06:08 PM
Evoryder's Avatar
what slowguy said...
adding meth without a tune is like buying race gas without upping the boost to take advantage. If you current tune is rich enough, you may encounter some knock..don't waste running meth without a tune.
And search...
Old Jul 30, 2007 | 08:23 PM
Sti THIS's Avatar
not that i dont want to tune it. I def plan on tuning it. Its just that i installed the snow performance meth kit and i was wondering if i could run it on no tune until i do so
Old Jul 30, 2007 | 09:06 PM
SlowCar's Avatar
do a few pulls, make sure everything is working/sprayng, no leaks - pull the fuse to it - reinstall on the tune day, get tuned.
what size nozzle and what mixture u runing?
Old Jul 31, 2007 | 03:36 PM
Sti THIS's Avatar
yea thats a good call^ i dont know exactly how big the nozzle was, it was the middle of the 3 they provided. its a 50/50 distilled water and dnatured alky, but i plan on running meth for the tune
How much boost shoud i be looking to run?
Old Jul 31, 2007 | 03:46 PM
SlowCar's Avatar
if you are running methanol, put the biggest nozzle in
you got headstuds and failsafe?
Old Jul 31, 2007 | 03:49 PM
Sti THIS's Avatar
snow performance comes with the safe injection controller.
Can i ask why i would put the biggest nozzle in for meth?
and headstuds and tune come at the same time
Old Jul 31, 2007 | 04:07 PM
SlowCar's Avatar
more methanol = greater latent heat/octane enhancement = safer...with failsafe
Old Jul 31, 2007 | 04:18 PM
Evoryder's Avatar
plus flames lol
