HFS-5 Installed and Tuned!
Old Aug 9, 2007 | 01:43 PM
  #61
aqmist's Avatar
Originally Posted by 80210
That's real clean. Nice work. So you had to drill through your IC piping? Is there a way to plug it if you decide to take out the injectors?
Also, just wondering.. anyone know what the emissions are like when adding meth/water?
Probs not a lot different with the water... but meth?
The HFS-X kits come with 2 hard pipe adapters included with the kit purchase. These can be sealed with blanking plugs if the jet(s) need to be removed.
We also have soft pipe jet adapters for soft pipes such as those sold by Perrin, Samco, and Forge etc......
Old Aug 10, 2007 | 11:49 AM
  #62
xiaoni420's Avatar
Originally Posted by binh
I saw this install in person tonight. I'm still in awe.
It gave me motivation to get off my butt and do a similar install.
Xiaoni420, dude I already forget your real name....
But anyhow, where do I order the tank from? I'm most likely going to go with (1) 6 quart tank.
BTW, if you ever need meth I'm a VP dealer. I have tons of meth in either 5 gallon containers or by the gallon out of drums. I'm located in South Jersey. Let me know.
Binh
Binh thanks for the refill bud!! I really appreciate it. If anyone needs meth in the Philly/South Jersey area, contact Binh. I just picked up about 7 gallons of VP M1 from him.
-Nick
Old Aug 10, 2007 | 12:15 PM
  #63
binh's Avatar
-Nick
No problem man. I know what its like to be in a bind like that. Good luck with your studies and see you next year.
Old Aug 11, 2007 | 10:10 AM
  #64
aqmist's Avatar
Binh, Please PM me your contact info. I sometimes get people who ask me for a methanol source, I would like to forward your info to them when get an inquiry.
Old Aug 11, 2007 | 10:14 AM
  #65
binh's Avatar
Thanks for your help. PM'ed you.
Old Aug 16, 2007 | 12:50 PM
  #66
xiaoni420's Avatar
Binh, you get your kit yet???
Old Aug 16, 2007 | 03:57 PM
  #67
binh's Avatar
Yep. Got it today. You shoulda seen me at work piecing together the pump fittings.
Nick, the bottom 2 holes of the pump bracket...what did you bolt that to? Just the backing divider piece of the car?
Old Aug 16, 2007 | 04:08 PM
  #68
Duby's Avatar
I love the double tank setup. Do you have to do anything special and how does low fluid level work on somthing like that ?
Old Aug 16, 2007 | 05:10 PM
  #69
xiaoni420's Avatar
Here is a pic to help Binh and everyone else out who are going with the twin tank setup. This is all the braketing involved with the extra support strip.
Old Aug 16, 2007 | 05:14 PM
  #70
xiaoni420's Avatar
There is a float sensor that cuts boost when the tanks run low.
Old Aug 16, 2007 | 07:07 PM
  #71
aqmist's Avatar
Binh, stuff went out priority mail today. I think you should have by Saturday.
Duby, we have put together a new part number that has the fittings necessary for a dual tank setup. To expand a little on what nick said above, the float sensor is tied into the W/A system as an active system component, theres a light on the DDS3 that gives you a water level status AND if by chance you were to run low on the road the DDS3 can shut down the W/A system and trigger a failsafe output such as dump boost or switch maps so you can protect things when under a low supply level condition.
Old Aug 16, 2007 | 07:46 PM
  #72
APEX1's Avatar
I got my kit today! Thanks Jack I will have dyno numbers next week.
Wheeeeeeeee
Old Aug 16, 2007 | 09:20 PM
  #73
binh's Avatar
Jack, thanks a ton.
Another badass setup is on its way. I'll have pictures up eventhough they are identicle to Nicks
Old Aug 16, 2007 | 09:35 PM
  #74
fixem2's Avatar
xiaoni420, is that 3 strips on the bottom? 2 on the trunk side and 1 on the back seat side in a sandwich format?
Old Aug 16, 2007 | 11:44 PM
  #75
Duby's Avatar
I have this kit, i was wondering how the sensor would work for both tanks or does it work for one beacause they are equally drained ?
