Loud Snow Performance Pump
Old Aug 14, 2007 | 11:08 AM
GOTBOOST1023's Avatar
I just installed a snow performance kit and the pump is very loud when it turns on. Is that normal? I have it mounted under the stock washer tank.
Also my safe injection module in leaking with just 50/50 meth and water. I can see the drips on the tranny. Is it defective? Also when is the light for the safe injection supposed to come on?
Old Aug 14, 2007 | 11:50 AM
SlowCar's Avatar
is it loud from the on-demand switch switching the pump on and off...or is it running noisy?
viscosity of goes down from water to methanol ie more methanol in the solution, the more likely it will leak if there is a leak.
dont all snow kits come with a tube of GOOP?
Old Aug 14, 2007 | 12:32 PM
It is running noisy. It is really loud when the pump engages under boost. It almost sounds like a loud fuel pump. The leak is from the one line on the safe injection comming from the pump. Should I just put goop on it and call it a day?
Old Aug 14, 2007 | 12:36 PM
Also I have the vc25 controller set at 8psi start and 25psi max. It is all the way up. Should I turn down the max a little. My boost is set at 28. It seems like it running through the meth very fast.
Old Aug 17, 2007 | 10:05 PM
Ultimate CC's Avatar
hey,
are you still having the issues? if you are getting leaks make sure the lines are perfectly straight going into the SI as if they aren't it could be your problem...
Randal
Aug 28, 2013 02:10 PM
EvolutionRey
13
Jul 16, 2009 05:13 PM
Edo Performance
Feb 19, 2009 09:35 PM
EvoTech
32
Dec 13, 2007 04:30 AM
EvoTech
Jan 30, 2007 05:43 PM
