Does M3 methanol damage seals on SMC kits?
Old Aug 18, 2007 | 08:56 AM
KY's Avatar
KY
I was told that the M3 meth damages the seals on SMC kits faster than M1? Is this true?
I bought a new meth kit and it didn't work when I got it. There wasn't enough pressure. Well I sent it to SMC and got it back and it worked fine. About 2 months later it still works, but I find myself going through meth really fast. I notice my trunk smells and the carpet is wet. I was leaking meth! It was spraying out of every possible location it could on the pump. I am using M3 and have been since I got tuned. Should I switch to M1?
Old Aug 18, 2007 | 10:07 AM
SlowCar's Avatar
i hope you are running a good failsafe AND not tuned too aggressively...
sigh
Old Aug 18, 2007 | 10:11 AM
boost_junky2000's Avatar
methanol is highly corrosive
Old Aug 18, 2007 | 10:13 AM
SlowCar's Avatar
water is worst
https://www.evolutionm.net/forums/sh...2&postcount=54
Old Aug 18, 2007 | 11:46 AM
94AWDcoupe's Avatar
welcome to pumps run with meth.
Old Aug 18, 2007 | 12:29 PM
SlowCar's Avatar
run it with water, ethanol....it will still happen on the smc flojet pump
this is a rv, hot dog cart pump...not a pump for critical applications like high pressure methanol injection on a car!
http://store.waterpumpsupply.com/fldidepu14gp.html
Old Aug 18, 2007 | 12:34 PM
High_PSI's Avatar
That is strange that it would leak like crazy. And if it is you are probably going to run lean as poop becuase you are certainly not running the proper volume needed to keep up with your tune.
Did you call SMC and ask them? I hope they once again replace your unit.
Old Aug 20, 2007 | 08:14 AM
KY's Avatar
KY
Yes, I emailed Steve and he said it will be fixed at no cost to me except for shipping to him. He also said the lubricants in M3 damages seals. I am going to switch to 75% M1 and 25% water and get retuned. Hopefully this will allow the pump to last longer.
Old Aug 20, 2007 | 09:08 AM
SlowCar's Avatar
please do your motor a favor, run a good failsafe at least
Old Aug 20, 2007 | 10:50 AM
TTP Engineering's Avatar
I have no problems running M3 through shurflo based pumps. You may want to reconsider the flojet garbage.
Old Aug 27, 2007 | 01:15 PM
AlwaysinBoost's Avatar
I used that pump on an AWIC system I had in another car.
Old Aug 27, 2007 | 01:36 PM
Evoryder's Avatar
such tact
Old Aug 27, 2007 | 06:38 PM
KY's Avatar
KY
I didn't know there was so much dislike for SMC and their pumps. I remember when Al first started promoting these kits and everyone was all over them. I guess times change.
Old Aug 27, 2007 | 06:44 PM
Evoryder's Avatar
They were hot before the seals started going out prematurely...
Old Aug 27, 2007 | 06:54 PM
SlowCar's Avatar
the flojet pumps used in the smc systems are put under tremendous stress, working at pressures in excess of ~3X they are designed for......under stress things break....
http://www.flojet.com/files/rlf_series_f100-196.pdf
