help!!! METH AND WATER MIX!! aquamist
Old Aug 23, 2007 | 11:35 AM
deadbeatrec's Avatar
ok so im getting the aquamist installed and tuned by Sean Ivey and his mechanical on the 14th of sept. i wanted to know if there is anything special i have to do b4 this.
here are my mods.
Buschur 3” cat back
Buschur 3”test pipe
Forge diverter valve
Hallman mbc
255 walbro fuel pump
Full Race exhaust manifold
NGK BR7ES gaped to .026
780 cc Buschur injectors
Buschur deluxe FMIC
HKS 272 Intake cam
HKS 272 Exhaust cam
ATP 3037S/3076R turbo kit
Pruven Performance custom made intake
Pruven Performance custom made LICP
Pruven Performance custom tune
do i need NGK BR8ES plugs?
and when mixing the water and the meth, is there anything i need to know? anything special? i wanted to run 66% meth 33% water. do i simply just do 66% of 6 liters and add that to 33% water?
what size nozzle? the kit comes with .08 .09 1.0mm nozzles.
Old Aug 23, 2007 | 11:53 AM
Turbo Meg's Avatar
I can only add to use distilled water.
Old Aug 23, 2007 | 12:16 PM
what?
Old Aug 23, 2007 | 12:20 PM
SlowCar's Avatar
tap water leaves behind "residual" when it dries, which might crust around the jet orifice and reduce the aperture.
distilled water dries leaving nothing behind was what he was refering to
Old Aug 23, 2007 | 12:31 PM
i realize this. no offense but that didnt answer any of my questions.
also i was thinking that the stock uicp has to be drilled and taped, but is the wall thick enough?
Old Aug 23, 2007 | 12:52 PM
EvoTio's Avatar
I'm presently running a 60% methanol/40% distilled water concentration on my Aquamist 2D system. I mixed 5 gallons of methanol and 4 gallons of distilled water. As for nozzle choice, what Aquamist system are you running?
Old Aug 23, 2007 | 12:55 PM
i have the HFS-1
also what about the UICP? is the wall thick enough to tap?
Old Aug 23, 2007 | 02:28 PM
EvoTio's Avatar
Originally Posted by deadbeatrec
i have the HFS-1
The stock UICP is actually pretty beefy in thickness. Here's a link to my install on the Aquamist forums. Scroll down and you'll find a pic of my nozzle mounted in the UICP: http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=654
As for the nozzle, I would run at least a 1mm nozzle since you have a larger percentage of methanol to water. I'm currently running twin .8mm nozzles on my set up. SlowCar is running twin 1mm nozzles, that's probably even the better way to go with your Aquamist/Shureflow pump.
Old Aug 23, 2007 | 03:46 PM
Sharkbite2000's Avatar
Very nice job very very clean
Old Aug 23, 2007 | 04:55 PM
ok so i wont have any problems taping the uicp? and what about my spark plugs? should i put some NGK BR8ES in there and gap them smaller? like .024"-.026?
Old Aug 23, 2007 | 05:29 PM
XSivPSI's Avatar
Thats 55.56% Meth
Old Aug 23, 2007 | 05:30 PM
EvoTio's Avatar
Yeah, there should be no problem tapping the UICP, just use the correct tap recommended by Richard and make sure you use Locktite Red along with your Aquamist brass fiitings. You want make sure they are secure and tight and that there are no leaks under boost.
As for spark plugs, I'm using Denso IW-22's (stock heat range replacement) gapped at 026 with no problems. I tried the colder IW-24's and was getting some high RPM spark blow out with the gap at 026. I want to get an ignition upgrade of some sort and run the colder plugs without having to reduce the spark plug gap.
Old Aug 23, 2007 | 05:33 PM
EvoTio's Avatar
Originally Posted by XSivPSI
Thats 55.56% Meth
Lol, I knew someone would come out and get it down to the last percentage. O.K I'm running a 55.56% ratio .
Old Aug 23, 2007 | 05:34 PM
EvoTio's Avatar
Thanks.
Old Aug 24, 2007 | 04:21 AM
https://www.evolutionm.net/forums/sh...d.php?t=288728
this is what i found for the tap and drill sizes. richard can u confirm?
