New AEM kit or Snow 2D kit?
Old Aug 31, 2007 | 08:10 AM
  #31
SlowCar's Avatar
Originally Posted by uSmC_08
So what would be a simple on/off system?
Thanks
i would suggest the aquamist hfs-1 - because its just damn hard to beat for the price
- the pump used in the hfs system is not one use by everyone else. this pump does not use a "on-demand" switch to regulate pressure but triple pressure regulating valves within the pump head. Note in the video the initial movement when the 150W shurflo/aquamist starts, then it purrs away maintaining @125psig. The "on-demand" pump switches the pump on/off to maintain pressure...imagine 0 throttle/full throttle action...
Also by doing away with the "on-demand" switch on the top of the pump head, a potential source of leak is eliminated
http://media.putfile.com/pumpjump
-the rest of the components...
notice the attention into even the most minute detail...its a system that you want to show off in a car show, not one you want to tuck away in the cubby hole on the left side of the trunk
this is my hfs-1 setup
-the failsafe gauge
when setup after the car is tuned, will detect injection faults before the onset of high afr/egt. i have been using the same dds3 for almost 4 years, went from my viii into the ix. Richard sent me the new style bezel to replace the older chrome blingy style
this hfs-1 is easily upgradable to the ultimate IDC based hfs-5 injection system with the addition of the High Speed Valve/FiA2 if you decide to go that route
there are a lot of systems out there, do your research on different systems/ mode of injection delivery/ quality of components/ technical help with the system and even the science behind WAI and do not just go for the best deal
