methanol + water = hot
Old Sep 3, 2007 | 06:49 PM
SlowCar's Avatar
today, i mixed 12L solution of 75methanol:25water and the mix got hot. Could feel the heat thru a 1/4" thick fuel jug...
what possible reaction is there between H2O and CH3OH that will cause the exotherm
methanol = CMOS grade
water = 18MOhm DI, fresh from tap
chemistry guru?
Old Sep 3, 2007 | 07:03 PM
SaOrlando's Avatar
i believe you are looking at co2 and h2 being made as a byproduct of ions
Old Sep 3, 2007 | 07:11 PM
SaOrlando's Avatar
It is an exothermic reaction, btw.
Methanol also forms co2 and h2o when it burns.
The product "heet"(used to take water out of gasoline) is actually methanol or a mix of methanol.
Old Sep 3, 2007 | 07:12 PM
SlowCar's Avatar
something is reacting...
i read of this effect from c6c6ch3vo post. tried a 100cc mix in a foam cup a few months back and temp went up
https://www.evolutionm.net/forums/sh...6&postcount=12
Old Sep 3, 2007 | 07:18 PM
sikrsix's Avatar
I am no chemist but arent you suppose to be using distilled water? Not that it changes your findings at all. But I was always told distilled water only.
Old Sep 3, 2007 | 07:22 PM
nothere's Avatar
I think distilled water is used to keep the jets from clogging with minerals and other junk
SlowCar's Avatar
the water is very very very pure......18MOhm resistivity...
Old Sep 3, 2007 | 07:28 PM
SaOrlando's Avatar
There will always be very low volumes of Hydrogen and Oxygen atoms in water, and in methanol; Carbon, Oxygen and Hydrogen atoms. Those "loose" atoms will join in a exothermic reaction to make H2 and Co2.
Old Sep 3, 2007 | 08:28 PM
dubbleugly01's Avatar
not a chemist, but a chemical engineer if that counts, lol. When you dilute meth with water, there is an exothermic reaction. Not sure of the chemistry, but it is fact. The heat generated shouldn't be extreme (i.e. melt the container), but you will see a temperature rise.
Old Sep 3, 2007 | 08:41 PM
cfdfireman1's Avatar
should the H2O be added to the meth or visa versa? if it rains on my car am I in trouble?
Old Sep 3, 2007 | 09:08 PM
SaOrlando's Avatar
Pouring one into the other will not matter as it wont melt or burn anything.
Although, I would avoid getting water on your car, it might catch on fire.
Old Sep 3, 2007 | 09:11 PM
cpoevo's Avatar
I mix 50/50 and when I mix the two together the jug gets really warm. When I pour it in the car the tank in the car will get really cool after a while. I dont really woryy about it.
Old Sep 3, 2007 | 09:14 PM
dcorn's Avatar
Sweet, can't wait to find this out when I get my Snow kit this week
Old Sep 4, 2007 | 08:38 AM
Ultimate CC's Avatar
yea first time i mixed the two i freaked out...then just hit the chem books up and was relieved...it definitely gets hot though...
Old Sep 5, 2007 | 01:53 PM
dudical26's Avatar
I also noticed that mixing the two creates heat. Fortunately I know so little chemistry, I just figured it was normal, lol.
