Miss fire at 25 PSI w/ meth?
If Milo's Evo is a IX, which I'm guessing it is since its an MR SE, then no one makes copper plugs for the Evo IX yet. I've seen a lot of people blow out spark at higher boost, and it seems like gapping to 0.22 works pretty good. Thats what I'm going to try before I start tuning for my HSF-5 kit.
with a functioning DLI and a .28 gap on a healthy plug he is not blowing out the spark
1. Your DLI could be acting up. we do not even carry them anymore beacuse of the failure rate they have
2. If you are pushing the meth test button and the car is not changing in idle or in its A/F mitxture then the methanol kit is not working correctly.
3. Try bypassing the DLI with the stock ignition to see if it gets any better. If it does but the car still misses, lower the boost. If that cleans it up you know your DLI is the culprit and that the factory ignition cant take 28Psi
The fact that your meth Test button does not change the A/F readings at all is not a good sign though
Eric
__________________
Sales Manager
AMS Performance
1760 Metoyer Ct
West Chicago, IL 60185
www.amsperformance.com
Eric@amsperformance.com
847 709-0530
https://www.evolutionm.net/forums/sh...0&postcount=33
Eric
__________________
Sales Manager
AMS Performance
1760 Metoyer Ct
847 709-0530
Eric
__________________
Sales Manager
AMS Performance
1760 Metoyer Ct
847 709-0530
Eric
__________________
Sales Manager
AMS Performance
1760 Metoyer Ct
847 709-0530
I'll pray to the EVO GOD and hope that its just my spark plugs are gapped too wide. I'd be pretty upset if its my HKS DLI acting up, considering I just purchased it 2 weeks ago. If it was my HKS DLI would it not break up at 24psi as well? My Evo runs pretty strong at 24psi w/ meth
I just gaped my stock plugs at .020. The idle is a little more lopy but ,when you hit the gas it feels more smooth than before but, the engine light still came on???
Any more suggestions?
different plug?
new ignition?
turn boost down?
The car runs and feels fine but, I just don't like driving around with this light on!
HELP??
different plug?
new ignition?
turn boost down?
HELP??
Just purchase a new set of Greddy spark plugs..........I'll test them out later today. Hopefully it can withstand 25psi thru 30psi of boost..............wish me luck boys and girls
