MAC Solenoid connectors
What connectors are people using to connect hoses to the MAC solenoid?
I thought it was gonna come with some brass barb connectors...no dice. Now I need to get some.
Where did you get them / any part number or something to look for?
Thanks,
Jeff
Thanks,
Jeff
the 3 ports on the mac valve are 1/8NPT female
the 1/8NPT male X barb fitting, the barb side will be determined by the ID of your boost hose. You want the hose to fit tightly over the barb, to make sure it does not come off, even w/o ziptie or hose clips
try homedepot or ace hardware, you should be able to find something.
Call the supplier who sold you the Mac solenoid. They will have a very wide selection of barb fittings. Just tell them the solenoid you have and the ID diameter of your hose and they should be able to get you some bards very cheaply and quickly as well.
