Plugs for meth/35r
Old Sep 27, 2007 | 02:47 PM
E VOL IX's Avatar
Plugs for meth/35r
I just got tuned for my 35r and meth. I have one step colder densos in the car right now and the ignition was breaking up bad as hell on the dyno. I put on a sun auto ignition amp and i know they are fouled. My question is, should i just get another set of the 1 step colders or go two step with the meth? Or will that be too cold?
Old Sep 27, 2007 | 03:50 PM
E VOL IX's Avatar
anybody??
Old Sep 27, 2007 | 04:06 PM
APEX1's Avatar
bpr8es - ngk
Old Sep 27, 2007 | 04:08 PM
thatsMR2u's Avatar
br8es for copper or br8eix for iridium - dont get bpr cause its a prolonged tip which isnt good for high boost
APEX1's Avatar
gap at .18
and I see you upgraded the ignition. now if there is still an issue than you need the AEM EMS.
Old Sep 27, 2007 | 04:34 PM
E VOL IX's Avatar
this is a evo IX btw.. honesty i dont wanna pay 150bucks for NGK's. my friend runs 26psi on his 20g with meth with the densos and has no probs what so ever.
Old Sep 27, 2007 | 04:42 PM
APEX1's Avatar
I payed 10 bucks for mine.
try the 1- step colder which is a 8 series. gap no lower than .18
if this don't work than you need to turn boost down OR AEM ems. thas it dude?!
Old Sep 27, 2007 | 04:43 PM
evilempire76's Avatar
Buschur Racing has some copper plugs for the Evo IX. You can try those. They cost $25 for a set.
Old Sep 27, 2007 | 04:44 PM
evopower1021's Avatar
i have a 35r and run meth and i use ngk bpr8es gapped to .22 and have never had any problems
Old Sep 27, 2007 | 04:46 PM
E VOL IX's Avatar
No i dont need an ems... they were fine, they just were fouled on the dyno cause they were gapped at .27 we took them down to .24 on the dyno and no i just need new ones.. I was just wandering if two steps colder is too cold?
Old Sep 27, 2007 | 05:49 PM
dubbleugly01's Avatar
rule of thumb is one step colder than stock for every 100 hp more than stock you make. This is from the NGK website.
The colder plug won't clear up the ignition miss though. That's a separate issue and it sounds like you know they were fouled.
Just another datapoint.... I'm running 30#'s boost at a gap of .022 with no miss on NGK's.
Old Sep 27, 2007 | 07:21 PM
Duby's Avatar
what kind of power did you put down ?
Old Sep 27, 2007 | 07:38 PM
FL_SilverEvo8's Avatar
gap at .18
if he is running that sun ignition then he should gap them that low. (0.18) should he?
Old Sep 27, 2007 | 07:44 PM
.018 is awfully low regardless. I'd be looking for other mechanical/tuning issues that would require such a low gap. Maybe a weak ignition coil, plug issue, timing, etc....
GTVEVO's Avatar
In my experience its the ignition box, the sun box is an improvement but not enough to get you what you need to keep things clean. You shouldn't have to gap plugs that low with a additional box. Also with meth or water injection you do not always want to drop plug heat levels. I have the best luck with the stock heat range on alky/meth injection.
