Tons of meth - good or bad...
Old Oct 18, 2007 | 10:35 AM
  #31
Jasil's Avatar
You don't need that much meth too max out a stock turbo.
Old Oct 18, 2007 | 02:02 PM
  #32
SlowCar's Avatar
Originally Posted by Jasil
You don't need that much meth too max out a stock turbo?
how much meth do you need to max the stock turbo out - on stock injectors?
30psig peak boost, 12.5AFR...timing as near MBT w/o any knock?
Old Oct 18, 2007 | 02:09 PM
  #33
kinloch99's Avatar
please post when the engine
Old Oct 18, 2007 | 02:11 PM
  #34
05blue8's Avatar
I'd also like to know this also. I'm about to be tuned around 28PSI on 70% meth with dual 600cc nozzles. At this point the stock turbo is maxing or at least very close to maxing it's potential right?
Old Oct 18, 2007 | 02:13 PM
  #35
Mad_SB's Avatar
^^ please post when the engine laughs????
I'm sure it starts to giggle every time it gets mouth full of the good stuff
Old Oct 18, 2007 | 02:14 PM
  #36
SlowCar's Avatar
Old Oct 18, 2007 | 05:11 PM
  #37
aboh6leenz's Avatar
Originally Posted by SlowCar
lol....i did not see this early, was "kicking back" here in seattle the last 36 hrs
will be going in 2 hrs...post your question here and you will get your solution
I just wanted to be graced by your almighty presence... and to say you worked on my car. I'll pm you later though If i dont figure it out.
Old Oct 19, 2007 | 12:34 PM
  #38
C6C6CH3vo's Avatar
Abner, whats a "fixed orifice"?
Old Oct 19, 2007 | 01:57 PM
  #39
SlowCar's Avatar
huh?
Old Oct 19, 2007 | 06:50 PM
  #40
aqmist's Avatar
I think he means a restrictor.
Old Oct 19, 2007 | 07:04 PM
  #41
bnice01's Avatar
i put it this way with me a 1150 cc nozzle (100%), stock fuel pump, 30 psi spike, 25* of timing, 12.0-11.7 afr, no knock
my high throttle fuel % looked like my normal driving fuel % that how much fuel I was pulling out.
so I would have to say probably half that nozzle size with stock fuel pump could max out the stocker, i dont think timing could be that high though.
if you want I can post up a log I have when I had the stock 16g but my afr's are not datalogged
Old Oct 19, 2007 | 08:27 PM
  #42
BOOSTEZ's Avatar
The stock turbo can only hold 21-22psi to redline anyway. Why spike so high only for it to taper off very rapidly as the rpms go toward redline?
Yea, I had 22* of timing (at redline) on my Meth tune on 91pump @ 25psi.
-M
Old Oct 19, 2007 | 11:04 PM
  #43
DCsleeper's Avatar
There are a couple methods to keep boost up with the stocker. I have held 23 psi at 7200 in the past by varying the duty cycle on my GM BCS. Although since I have started to get into W/I my boost has come down at high rpms. I believe that this is due to the colder exhaust gases. My EGTs now with W/I are almost 100 degrees colder. You may have to keep the EGTs up higher to maintain higher exhaust gas velocities to hold more boost. Just a thought I am throwing out there. I am really new to the W/I game.
Old Oct 20, 2007 | 08:45 AM
  #44
bnice01's Avatar
-M
High spike more tq but I hold about 25ish (3rd gear pull) to redline (my shift point 72-7300) with my wga. gear changin I get about 26-27 average boost and 4th is the only gear I get 30 and it sits there finally tapering to 27ish.
Old Oct 20, 2007 | 01:06 PM
  #45
BOOSTEZ's Avatar
Impossible unless you have something no other stock turbo has. Do you have an upgraded wga or something? My car only holds about 21-22psi to redline (7200 rpms) on bone stock turbo.
-M
